Intel® C++ Compiler
7782 Discussions
stpncpy broken on OS X with icc version 12.1.5
Marc_Lavergne
Given the following test case on OS X:
#include
#include
int main(int argc, const char * argv[])
  char data1[8] = "foo";
  char data2[16] = "helloworld";
  // links and works
  // char* ptr = stpcpy(data1, data1);
  // links and works
  // char* ptr = strncpy(data1, data2, sizeof(data1));
  // doesn't link (Undefined symbols for architecture x86_64)
  char* ptr = stpncpy(data1, data2, sizeof(data1));
  printf("%s\\n", data1);
  return 0;
I get the following:
# icc main.c
main.c(16): warning #42: operand types are incompatible ("int" and "char *")
Undefined symbols for architecture x86_64:
  "___builtin___stpncpy_chk", referenced from:
      _main in icczDRt9N.o
ld: symbol(s) not found for architecture x86_64
The same code works fine under ICC for Linux. Since stpncpy is a part of libc, I'm assuming that this is a known bug in ICC for OS X?
Jeffrey_A_Intel
FWIW, I don't see any errors when compiling with
Intel® C Intel® 64 Compiler XE for applications running on Intel® 64, Version 12.1.6.367 Build 20120612
or
Intel® C Intel® 64 Compiler XE for applications running on Intel® 64, Version 13.0.0.088 Build 20120731
on Mac OS 10.8.  The command line was simply "icc test.cpp"
Both produce
hellowor??
when I run the resulting a.out.
