Intel® C++ Compiler
7956 Discussions
strange compiler behavior. OpenMP directives.
nuclear_trash
Hi!
I'm using Intel C++ Compiler 10.0.025, MS Visual Studio 2005 (as IDE).
My project is a dynamic library, which includes header-file with declaration of classes and some functions and cpp-file with the main export function there.
A strange thing is: compiler doesn't recognize a directives #pragma omp parallel for, located in the main export function in cpp-file.
i.e. it doesn't write OpenMP DEFINED LOOP WAS PARALLELIZED. as usual, it writes nothing, and parallelism doesn't work.
But! It happens only in release mode with the project's option runtime library: Multi-threaded (MT)
Compiler works correctly with optionruntime library: Multi-threaded DLL (MD)
But MD-mode is not good for me.
In debug mode all is correct in both cases (MTd and MDd)
All openMP pragmas in header-file are processed correctly.
How can one explain it?
nuclear_trash
no ideas?
TimP
No, you ask for speculation which probably would be irrelevant, since you don't give much detail. You'd probably have to update to a supported compiler version. If you still had a problem, you could submit the case on your premier.intel.com account.
