Intel® C++ Compiler
7942 Discussions
struct creation - segmentation fault
Michal_Kvasnicka
The attached source code produce segmentation fault after "init t2" with current C++ compiler:
Intel C++ Intel 64 Compiler XE for applications running on Intel 64, Version 12.1.1.256 Build 20111011 (Linux xXx 2.6.35-31-generic #62-Ubuntu SMP Tue Nov 8 14:20:11 UTC 2011 x86_64 GNU/Linux)
#include
#include
using std::max;
using std::cout;
struct tstruct
double a;
tstruct() : a(0) {};
int main(int argc, char *argv[])
cout << "init t1\\n";
tstruct *t1 = new tstruct[8];
cout << "init t2\\n";
tstruct *t2 = new tstruct[max(5,8)];
$ ./a.out
init t1
init t2
Segmentation fault
Any workaround or recommendation?
Michal
JenniferJ
It's a bug.
It can be work-arounded with a local variable for the "max(5,8)" like:
int nbignum=max(5,8);
tstruct *t2 = new tstruct[nbignum];
Thanks for reporting it.
Jennifer
Michal_Kvasnicka
I can trace back this bug up to version 12.0.2.
When can I expect the fix?
Om_S_Intel
Intel compiler development team is working on it. We will post an update here as soon as issue is fixed.
Please use the work arround for time being.
SergeyKostrov
Valued Contributor II
Here are a couple of examples:
struct DATASTRUCT
DATASTRUCT() : dA( 0.0L )
double dA;
int i;
//1
int iMax1 = max( 2, 4 );
DATASTRUCT **pDs1 = ( DATASTRUCT ** )new DATASTRUCT[ iMax1 ];
for( i = 0; i < iMax1; i++ )
pDs1 = ( DATASTRUCT * )new DATASTRUCT();
//2 - Notes:
// Constructor of the structure isNot called
// CRT-function 'calloc' initializes allocated memory with Zeros
DATASTRUCT *pDs2 = ( DATASTRUCT * )calloc( max( 2, 4 ), sizeof( DATASTRUCT ) );
//3
int iMax3 = max( 2, 4 );
DATASTRUCT **pDs3 = ( DATASTRUCT ** )calloc( iMax3, sizeof( DATASTRUCT * ) );
for( i = 0; i < iMax3; i++ )
pDs3 = ( DATASTRUCT * )calloc( 1, sizeof( DATASTRUCT ) );
Michal_Kvasnicka
I just test the latest release Version 12.1.3.293 Build 20120212 and the bug still here!?
What is the reason?
Georg_Z_Intel
our compiler engineers are still working on this (last activity was yesterday). Unfortunately we cannot name you the update release which will contain the fix right now. However, Jennifer will come back to you know once we have a compiler update that's validated.
If the workaround posted above should not be suitable for you we might work on an alternative for the time being.
Georg Zitzlsberger
JenniferJ
this issue is fixed in update 10 (12.1.4.319, Build 20120410). you can download the Intel C++ Composer XE for Linux update 10 from the Intel Registration Center. The evaluation pkg of Intel C++ Composer XE for Linux is also the latest.
I did the verification on IA32 Linux.
Jennifer
