Hello.
I've been trying o compile some packages like OenEXR, OpenCV... with Intel C++ Compiler on Linux. The compilation is succesfull but then, when I type
$sudo make install
I have an error: " 'icpc' command not found ", but I can invoque icp from my shell with no problems. I'm not a Linux shell expert so I hope anyone in this forum could help me. Please!....
I'm using Ubuntu.
$sudo make install
I'm using Ubuntu.
Your sudo command opens a new shell without copying your environment variables. If you need icpc in that shell, you will need to repeat the icc enviroment setup in that shell. Choose the appropriate iccvars.sh or csh.
Hello.
I've tried first adding this lines to /etc/profile:
$export PATH=/opt/intel/cc/my-vers/bin
$export LD_LIBRARY_PATH=/opt/opt/intel/cc/my-vers/bin
then I run sudo make install from my user account, then from sudo and i had the same error. Then, as sudo(sudo -i) i run iccvars.sh, and I had the same error :S.
please, help me:(
please, help me:(
LD_LIBRARY_PATH should contain /opt/intel/cc/version/lib
If your install went correctly, your iccvars.sh should contain the correct settings.
> su
> source intel/install/setvars.sh
> make install
Topic Options
