Intel® C++ Compiler
7838 Discussions
svml_* / libirc in Composer XE 2015 update 2 on Windows
pascalc
I have updated my Composer XE 2015 installation to the update 2 on a Windows PC, and it seems that svml_* and libirc libraries are gone. (In case my upgrade went wrong, I also did a repair of the installation.)
However, those libraries are still needed by MKL.
Any idea was is going on? Any suggestion on how to proceed?
JenniferJ
Something went wrong during installation. Those files are all there under [install-dir]\compiler\lib\[ia32|intel64]
what do you have under those two directories? All those files should be installed by default if you select to install ia32 or intel64.
Jennifer
pascalc
In the ia32 and intel64 directory, I only have the following files:
cilkrts.lib
gfxbegin.obj
libchkp.lib
libchkpwrap.lib
libchkpwrapmd.lib
libchkpwrapmd_h.lib
libchkpwrapmd_h_w.lib
libchkpwrapmd_w.lib
libchkpwrap_h.lib
libchkpwrap_h_w.lib
libchkpwrap_w.lib
libgfxoffload.lib
libicaio.lib
pascalc
I did a similar upgrade on a second computer (via the Intel Software Manager as well), and got the same result. Only those DLLs in the ia32/intel64 folders, no more svml_*/libirc libraries (as well as the many others I am currently not using).
