Intel® C++ Compiler
template aliases bug
rnickb
The following code compiles fine with clang and gcc (-std=c++14) but fails with icc 2016.
#include <type_traits>
#include <utility>
#include <tuple>
template<class Integer, Integer... Ix>
using IntegerSequence = std::tuple<std::integral_constant<Integer, Ix>...>;
template<std::size_t... Indexes>
using IndexSequence = IntegerSequence<std::size_t, Indexes...>;
int f(IndexSequence<Indexes...>) {
  return 0;
int main() {
  f(IndexSequence<3,7,8>());
  return 0;
Kittur_G_Intel
Hi Ryan,
Thanks, I've filed this issue with the developers and will touch base with you as soon as I've an update accordingly.
_Kittur
