following short example:
This code is working but what I really want something different.
[cpp]templateclass A { public: A():v_(T(0)){}; T get(){return v_;} private: T v_; }; template< template class Blub, typename T> T func(Blub &obj){ return obj.get(); } int main(int argc, char **argv) { A obj; func(obj); return 0; }[/cpp]
[cpp]template< templateclass Blub> T func(Blub &obj){ return obj.get(); } [/cpp]
gives:
tmplateMLPut2.cpp(12): error: identifier "T" is undefined
T func(Blub &obj){
With this I could instantiate func > and refering to "Modern C++ Design" this should work. I think I can handle my situation different...
So here my questions: Is the last case valid C++? If yes, why is it not working?
Cheers
Patrick
It is invalid. The scope of a template parameter extends from its point of declaration until the end of its template so the scope of "T" will end after the declaration of "Blub".
Thank you for your answer. Does this mean the best I can do is to define func like that:
The background of my question is the following: I have an Image class and some typedefs to, say BitImage, ByteImage, etc. and I want to write an ImageSender which is basically an adapter to a C-library to send images over a link. To send an image with the C-library I need 2 things depend on the type T of the image:
(img) which is imho unnatural because I want to send a
BitImage and it would be nicer to call sendImage(..).
Am I on a wrong way? Any ideas?
Cheers
Patrick
[cpp]templateand let the compiler deduce the type itselfclass Blub, typename T> T func(Blub &obj){ return obj.get(); }[/cpp]
[cpp]int main(int argc, char **argv) { A?obj; func(obj); return 0; }[/cpp]
- a string representation of the image type. BitImage->"Bit", etc.... I solved this with specializations of templates:
[cpp]template <> const char * getImageTypeString
(){ return "Bit";} template <> const char * getImageTypeString (){ return "Byte";}[/cpp] - for every image type T i need to select a different C-function. This is solved the same way with partial specialization.
[cpp]templateWhen I have to give the type of sendImage I have to say sendImagevoid sendImage(const Image &img){ /*use T in getImageString and the send-function ...*/ }[/cpp]
Cheers
Patrick
Compiler can deduce the type itself:
BitImage img;
sendImage(img); // Compiler will select getImageTypeString to return "Bit" if getImageTypeString called inside.
BitImage
