Hi - I was trying to use some code on StackOverflow for a 'thread on exit' function, but it wouldn't compile:
So I tried something simpler, and got the same problem:
#include <iostream> class Test { public: ~Test() { std::cout << "exit" << std::endl; } }; thread_local Test aTest;
The error message is:
error #1897: thread-local variable cannot be dynamically initialized
Should it compile? This is Intel C++ 16.0, in Windows Visual Studio Pro 2012, with C++11 enabled.
Dynamic thread_local variables require library support. Microsoft added this support in vs2015. If you'd like to use this feature please get the latest Intel 16.0 compiler (currently, update 1) to use with vs2015.
--Melanie
Hi Melanie - as I mentioned at the bottom of my post, I am using Intel C++ 16.0.
Intel(R) C++ Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.1.146 Build 20151021
is there something else I need?
John
Sorry - ignore my last reply. I'll try to update VS...
Managed to update to VS2015 (eventually - required re-installation of Parallel Studio) and code now builds; thanks
