Intel® C++ Compiler
tracking down Segmentation Faults
user20090419
Is there an icpc compiler flag (maybe -d or -g?) that would enable the debugger, so that if the code seg faults, it would print out the line / class where it happened? I don't need anything complicated like being able to step through the code, look up variable values in ddd, look for memory leaks etc. Having the debugger track all that makes the code run much slower. So I just want it to get to the seg fault as quickly as possible and print out where it happened.
dpeterc
I don't know of any such switch.
In my experience, ddd does that quite sasisfactory without running much slower, just at the speed of normal debug code.
Just do Status > Backtrace
in DDD after the crash, if it does not position you automatically to the line after the crash.
In some complicated cases, valgrind also helps pinpoint the error, as the error may be caused by trashing of memory prior to actual core dump. This indeed runs many times slower.
user20090419
Thank you. Can I use ddd with icpc, or I need to go back to g++? How do I use ddd with icpc?
dpeterc
Same way as you would with any other compiler. Compile your program with switch
-g
and then run it with ddd by
ddd executable_name
Intel compiler also comes wiht idb, which can be used in the same way.
idb exectuable_name
I perfer ddd, since it can nicely graphically display the data structures.
