Intel® C++ Compiler
type bug error with icc
rnickb
The following code compiles with gcc and clang but fails with icc.
#include <tuple>
#include <utility>
template<class, class>
struct right_impl {};
template <std::size_t... Indexes, class... Values>
struct right_impl<std::index_sequence<Indexes...>,
  std::tuple<Values...>>
  using type = std::tuple<
      std::tuple_element_t<sizeof...(Values) - sizeof...(Indexes) + Indexes,
                           std::tuple<Values...>>...>;
template<int N, class Tuple>
using right_t = typename right_impl<std::make_index_sequence<N>, Tuple>::type;
int main() {
  using T1 = std::tuple<int, float, char>;
  using T2 = right_t<2, T1>;
  static_assert(
    std::is_same<T2, std::tuple<float, char>>::value,
    "type is incorrect");
  return 0;
Kittur_G_Intel
I've filed this issue with the developers and will update you as soon as the release with the fix is out, appreciate much.
_Kittur
Kittur_G_Intel
Just letting you know that the 16.0 Update 1 version of the product released contains the fix for this issue which you can download and test it out, thanks.
_Kittur
