So far icc gave really good results. It has by default some nice flags (-Wshadow from gcc ...). But on the other hand there is one warning I don't quite follow:
warning #858: type qualifier on return type is meaningless
Here is an example to reproduce(*). If you uncomment those lines and try to compile it with gcc:
g++ -ansi -pedantic -Wall foo.cpp
It does not produce any warnings. Furthermore I do believe that const can be usefull for instance in this case. Is this correct or do I misunderstood something ?
Mathieu
#include >iostream<
const void foo()
std::cout "foo" std::endl;
int main()
//void (*p) () = &foo //const is usefull in this case
//p();
return 0;
Mathieu
#include >iostream<
const void foo()
int main()
//p();
return 0;
Please note that 'const' in you example is just related to function return type. And yes, it is really meaning less to use cv-qualifiers (const/volatile) for r-value return types, because you cannot modify them, especially it is useless for void return type.
Why do you fill const is useful in your example, what do you really want to get?
Max
Max
Max
Thanks for answering. Looking back at my question I realize it doesn't make much sense. so I just remove the const from my project.
But still, to be very picky, I think that 'void', eventhough it is not an object type, is still a type. Thus it can be cv-qualified (3.9.3).
And also another example :
template
const R foo(const ARG) {
foo(5);
What would icc undersand from that ?
Thanks again
Mathieu
template
foo(5);
Thanks again
Mathieu
Mathieu,
Your example is incorrect, because you cannot automatically deduce template parameter value from return type:
test02.cpp(8): error: no instance of function template "foo" matches the argumen
t list
argument types are: (int)
foo( 0 );
You can call only foo< void >( 0 ), explicitly specifying type for return value. It compiled without that warning, it is reasonable because off in generic case it is make sense to use const to return value. e.g. operator + () for some overloaded type like complex, you should use const:
const complex operator + ( complex const &, complex const&)
to repeat behavior of the plain types, because you cannot write
int a, b; (a+b)=0;
But without const in operator + declaration for complex you can write such code.
Hope, I've correctly understand and answered your question, have I?
Max
Mathieu,
test02.cpp(8): error: no instance of function template "foo" matches the argument list argument types are: (int)
foo( 0 );
const complex operator + ( complex const &, complex const&);
int a, b; (a+b)=0;
Max
foo( 0 );
int a, b; (a+b)=0;
Max
Message Edited by Max_Locktyukhin on 08-23-2004 07:23 AM
Max,
Ok you are right, I was wrong. Thanks for taking the time to answer me.
Mathieu,
You was not wrong, you asked the question! :)
Please, don't hesitate to ask questions here in future, we really want to make this forum useful for our compiler users.
Thank you,
Max
Thank you,
Max
Message Edited by Max_Locktyukhin on 08-24-2004 12:22 AM
