Hi
OS :: win2k8 R2
compiler :: icl version - 12.0.5.229 Build 20120731
compile and link line on top of attached c source code
Consider this disasm
Func4:
0000000000000064: 66 90 xchg ax,ax
0000000000000066: 55 push rbp
0000000000000067: 48 83 EC 70 sub rsp,70h
000000000000006B: 48 8D 6C 24 30 lea rbp,[rsp+30h]
0000000000000070: 48 89 75 30 mov qword ptr [rbp+30h],rsi
0000000000000074: 48 89 5D 28 mov qword ptr [rbp+28h],rbx
0000000000000078: 4C 89 4D 18 mov qword ptr [rbp+18h],r9
000000000000007C: 4C 89 45 10 mov qword ptr [rbp+10h],r8
0000000000000080: 48 89 55 08 mov qword ptr [rbp+8],rdx
0000000000000084: 48 89 4D 00 mov qword ptr [rbp],rcx
0000000000000088: 89 4D 50 mov dword ptr [rbp+50h],ecx
000000000000008B: 89 55 58 mov dword ptr [rbp+58h],edx
For PUSH instruction, we need to decrement the stack pointer i.e;RSP by 8bytes in case of 64-bit machine
Similarly do we have any other such instructions in above disasm where we need to modify rsp or rbp?
If yes, what and why
If no,
Please find attached sample code which tries to get argument by tracing back assembly
I see the rsp is not pointing correctly it is pointing 8 bytes ahead of correct position
output of sample code
Here initially rsp is 1afd10
push decremented it by 8bytes --> 1afd08
sub 70h made it -->1fac98
add 30 made it --> 1afcc8 and this is loaded into rbp and all args are pushed wrt to rbp
But if you see memory all args are pushed wrt to address 1afcc0....so i see 8 bytes difference...I am not getting
where i lost this 8 bytes.
Let me know your inputs on this.
compile and link instructions are on top of file
Not sure if sample source code attachment came properly -- so here is the link....you can download from here as well
https://www.dropbox.com/s/gvkmmigt6u5tdmm/sample.c?dl=0
or
plz find the attachment
