void __attribute__ ((visibility("default"))) foo();
and in foo.c
#include "foo.h"
#include stdio.h
void foo()
printf("foo()");
When I try to compile this with icc it fails:
icc -fvisibility=hidden -fpic -o foo.o -c foo.c
icc -fpic -shared -o libfoo foo.o
foo.o: In function `foo':
foo.c:(.text+0x18): undefined reference to `printf'
ld: libfoo: hidden symbol `printf' isn't defined
ld: final link failed: Nonrepresentable section on output
The same code with gcc compiles fine:
Compiler versions:
gcc (GCC) 3.4.4 (Gentoo 3.4.4, ssp-3.4.4-1.0, pie-8.7.8)
Intel C Compiler for 32-bit applications, Version 9.0 Build 20050722Z Package ID:
This has been corrected in the Intel Compiler package 9.1.045 now available for download.
# fails with 9.1.044 or earlier:
$ /opt/spdtools/compiler/ia32/cc-9.1.044/bin/icpc -fvisibility=hidden -fpic -o foo.o -c foo.c
$ /opt/spdtools/compiler/ia32/cc-9.1.044/bin/icpc -fpic -shared -o libfoo foo.o
foo.o(.text+0x1b): In function `foo()':
# works with 9.1.045
$ /opt/spdtools/compiler/ia32/cc-9.1.045/bin/icpc -fvisibility=hidden -fpic -o foo.o -c foo.c
$ /opt/spdtools/compiler/ia32/cc-9.1.045/bin/icpc -fpic -shared -o libfoo foo.o
If you are intersted in -fvisibility, we have anicewhite paper on Linux symbol preemption & performance implications / speedup possibilitiesat http://www3.intel.com/cd/ids/developer/asmo-na/eng/dc/tools/compilers/198900.htm
best regards,
_|ohnO
