hi,
im just new here. i am making a vamp plugin and uses aubio library for it. i just got the vamp-aubio.lib from dll-to-lib converter.
now i encounter this error after linking the project.
>vamp-aubio.lib(vamp-aubio.obj) : error LNK2019: unresolved external symbol __imp____lc_codepage referenced in function _VAMP-AUBIO_DllMain@12
hope anybody could help me with this.
thanks.
thanks.
Have you checked the glibc version requirement of your plugin, and installed compatibility libraries if applicable?
Quoting - tim18
thanks for the reply.
what do you mean of the glibc version?. i used the vamp sdk which was provided in the vamp website.
i am using some codes from aubio library, i already linked the vamp-aubio.lib in
Properties
what library is lacking?.
ezah
Oh, it's a windows library. You didn't say that. Is it intended for some version of Visual Studio, or for mingw32 or some other programming system?
Quoting - tim18
you mean the vamp-sdk? nope its the vamp plugin sdk. if i got it right, vamp plugin sdk uses Visual Studio C++ 2008.
Does the "link error" happen with Intel C++ compiler only?
Quoting - Jennifer Jiang (Intel)
No, I am using Visual Studio C++.
Quoting - ezah
But I did google, and found one place that /MT or /MD will make a difference. So if you're using /MT, try /MD.
If it's VC only, this is not the right forum.
Oh sorry, I'm just new here.
In what forum do I have to post about this?.
Thanks for the reply...
I still don't solve it. Im using /MDd.
ezah
Quoting - ezah
