I was using
#if __INTEL_COMPILER_BUILD_DATE >= 20140318
#pragma omp simd reduction(max: x)
#endif
and
#pragma omp simd lastprivate(index) reduction(max: x)
#endif
to enable building with various versions of ICL. gcc seems not to benefit from these pragmas, although they are accepted. 14.0 update 3 evidently breaks this scheme with its more recent build date but lack of full omp simd support. The erroneous use of #pragma omp simd without the required lastprivate and reduction (rejected by 14.0) clauses worked on some targets for 13.1 and 14.0.2 but not others. According to my understanding, "correct" usage for 14.0 is to avoid simd pragmas entirely in cases where there is a max or min reduction, but it seems there should be a way short of disabling the pragma for all intel compilers.
I haven't been able to see a method with the predefined macros to select the different variations of #pragma omp according to whether Intel 14.0 or some other compiler is in use.
It's difficult enough that Intel and gcc chose different interpretations of #pragma omp simd and that Intel has made several changes.
Another annoyance with 14.0.3 is the tendency to install the new front end hooked up to the previously active back end. The repair option doesn't fix this; it's necessary to uninstall and repeat install from the downloaded files until it gets done right. On-line install appears totally unsatisfactory due to its tendency to quit in the middle with an undefined state.
I can't get __INTEL_COMPILER or __INTEL_COMPILER_BUILD_DATE to work as expected with icc-15.0 or icc-14..3 when they are guarding #pragma omp <something>. I have to define my own macro to get the expected behavior, but at least reduction(max: var) seems to be working with icc-15.0
#ifdef ICC15
// if( __INTEL_COMPILER == 1500)
// if (__INTEL_COMPILER_BUILD_DATE >= 20140318)
cout << "\n compiled with reduction(+:s) reduction(max: max_x)";
#pragma omp simd aligned(a : 32) reduction(+:s) reduction(max: max_x)
#else
cout << "\n compiled with just reduction(+:s)";
#endif
=======================icc-14.0.3===================
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.3.174 Build 20140422
Copyright (C) 1985-2014 Intel Corporation. All rights reserved.
$ icc -openmp gcc_omp_simd-4.cpp && ./a.out
__INTEL_COMPILER = 1400
__INTEL_COMPILER_BUILD_DATE = 20140422
max_x = 38
sum = 19456
PASSED
========================icc-15.0=====================
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.0.024 Beta Build 20140318
icc: NOTE: The Beta evaluation period for this product ends on 28-aug-2014 UTC.
$ icc -openmp gcc_omp_simd-4.cpp -DICC15 && ./a.out
__INTEL_COMPILER = 1500
__INTEL_COMPILER_BUILD_DATE = 20140318
max_x = 38
sum = 19456
PASSED
Patrick
icc-150 and g++ 4.8 both accept:
icc-14.0.3 won't accept the max reduction.
#if __INTEL_COMPILER == 1500
#endif
#elif __INTEL_COMPILER == 1400
#elif (__GNUG__ >= 4) && (__GNUC_MINOR__ >= 7)
#endif
$ icc -V
$ ./a.out
max_x = 38
sum = 19456
PASSED
$ g++ --version
g++ (GCC) 4.8.1
$ g++ -fopenmp gcc_omp_simd-4.cpp
$ ./a.out
__GNUG__.__GNUC_MINOR__ = 4.8
max_x = 38
sum = 19456
PASSED
Patrick
OK, I'll try that. Reading the doc gave me the impression numeric values of __INTEL_COMPILER were no longer supported.
The __GNUG__ macro should be __GNUC__ when using gcc as opposed to g++. I'd been using stuff like that.
I noticed there is now a command line option which should stop icc from defining __GNUC__.
