Hello all,
I am compiling with 11.1 Fortan compiler, using flags '-integer_size 64 -real_size 64 -double_size 128'.
My questions is do these compiler flags also effect complex declarations?
Will the declaration "COMPLEX A" be cast to 'DOUBLE COMPLEX A"?
Also how about intrinsic call "conjg()" ? Will it automatically be recast to dconjg() or do I need to edit the source to explicitly call 'dconjg' ?
-Jeff
-Jeff
Here is a tiny test program to answer some of your questions. Expand it to answer the rest.
[fortran]program tcmplx real :: r; double precision :: d; complex :: c write(*,*)sizeof,sizeof(d),sizeof(c) end program tcmplx[/fortran]With the different compiler switches that you listed, here are the outputs.
[bash]~/LANG> ifort cmplx.f90 ~/LANG> ./a.out 4 8 8 ~/LANG> ifort -real_size 64 cmplx.f90 ~/LANG> ./a.out 8 8 16 ~/LANG> ifort -real_size 64 -double_size 128 cmplx.f90 ~/LANG> ./a.out 8 16 16[/bash]
