Community
cancel
Showing results for
Search instead for
Did you mean:
churunmin
v11.1 problem
why the following code fire warning
unsigned short a = L"";
in v11.0, I can use the multibyte character
Brandon_H_Intel
Quoting - churunmin
I can reproduce a "warning #26: too many characters in a character constant". Is that the one you are seeing?
churunmin
yes, why cannot I use non-ascii character?
gcc has a option "-finput-charset=GBK", it seems icc11.1 does not has one.
is there a way to specify charset for icc11.1?
icc11.0 defaults to system default charset
I think this is now solved.
[bash]icc -V
Intel C Intel 64 Compiler XE for applications running on Intel 64, Version 12.0.4.191 Build 20110427
Copyright (C) 1985-2011 Intel Corporation.  All rights reserved.
cat bug.cpp
const wchar_t *a = L"";
icc -c bug.cpp
[/bash]
I've got even no error if I use Compiler 11.1 Update 7.
Alex
