Hi
I'm using intel icc to compile a test program, and I find the value of variables not showing correctly when I compile the code with -O3 option.
here is my test code. //test.c
#include <stdio.h>
void f(int argc, char* argv[])
int i = 0;
for(;i<argc; i++)
printf("%s\n", argv[i]);
int main(int argc, char* argv[])
f(argc,argv);
return 0;
when I use -O0 option, the variables of argv show correctly as below.
[root@icelake test]# icc -g -O0 -o test test.c
[root@icelake test]# gdb-ia --args test 1 2 3 4
GNU gdb (GDB) 8.2.1
Copyright (C) 2018 Free Software Foundation, Inc.; (C) 2019 Intel Corp.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-pc-linux-gnu".
Type "show configuration" for configuration details.
For information about how to find Technical Support, Product Updates,
User Forums, FAQs, tips and tricks, and other support information, please visit:
<http://www.intel.com/software/products/support/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from test...done.
(gdb) b main
Breakpoint 1 at 0x4005c3: file test.c, line 12.
(gdb) r
Starting program: /root/test/test 1 2 3 4
Breakpoint 1, main (argc=5, argv=0x7fffffffd188) at test.c:12
12 f(argc,argv);
(gdb) p argv[0]
$1 = 0x7fffffffd4fd "/root/test/test"
but when I use -O3 option, the variables of argv show NOT correctly as below.
[root@icelake test]# icc -g -O3 -o test test.c
GNU gdb (GDB) 8.2.1
(gdb) b main
Breakpoint 1 at 0x400b59: file test.c, line 12.
(gdb) r
Breakpoint 1, main (argc=5, argv=0x3) at test.c:12
12 f(argc,argv);
(gdb) p argv[0]
Cannot access memory at address 0x3
when compiling with -O3, the program can still run OK except the variable not showing correctly.
my intel icc version is :
[root@icelake test]# icc --version
icc (ICC) 19.0.4.235 20190416
Copyright (C) 1985-2019 Intel Corporation. All rights reserved.
[root@icelake test]# whereis icc
icc: /opt/intel/system_studio_2019/compilers_and_libraries_2019.4.235/linux/bin/intel64/icc /opt/intel/system_studio_2019/compilers_and_libraries_2019.4.235/linux/bin/intel64/icc.cfg
Yes, but the address at 0x3 is invalid.
Anyway, the compiler version you have is old. I tried the new one (icx) and didn't see the issue.
Can you try Smart, Connected Device Development with Intel® oneAPI IoT Toolkit?
Thanks for providing the sample reproducer and the required details.
We are able to reproduce the issue at our end. We are working on it, we will get back to u soon.
Meanwhile, please refer the below link for more details about compiler optimization flags.
Shanmukh.SS
Seems like when you compiled with -O3, the compiler optimizes it away.
$ icc -g -O3 -o test test.c
$ gdb-ia --args test 1 2 3 4
GNU gdb (GDB) 8.2.1
(gdb) b main
Breakpoint 1 at 0x400ac9: file test.c, line 14.
(gdb) r
Starting program: /tmp/test 1 2 3 4
Breakpoint 1, main (argc=5, argv=0x3) at test.c:14
14 f(argc,argv);
(gdb) s
f (argc=<optimized out>, argv=<optimized out>) at test.c:6
6 int i = 0;
(gdb) n
12 {
(gdb) s
14 f(argc,argv);
(gdb) s
f (argc=<optimized out>, argv=<optimized out>) at test.c:7
7 for(;i<argc; i++)
(gdb) p argv[0]
value has been optimized out
(gdb)
Hi Viet,
thanks for your help. actually, I find it's a little strange that the argv of main function is not showing optimized, only the argv of f function is.
(gdb) b main
(gdb) r
Starting program: /root/test 1 2 3 4
12 f(argc,argv);
(gdb) s
f (argc=<optimized out>, argv=<optimized out>) at test.c:5
5 int i = 0;
(gdb) p argv[0]
(gdb) bt
#0 f (argc=<optimized out>, argv=<optimized out>) at test.c:5
#1 main (argc=5, argv=0x3) at test.c:12
(gdb) f 1
12 f(argc,argv);
(gdb) p argv[0]
(gdb)
ok, I switched the compiler to icx. as you said, the argv variable of main function can be showed correctly now even I compile with -O3 option.
thank you.
(gdb) bt
#0 f (argc=<optimized out>, argv=<optimized out>) at test.c:6
#1 main (argc=5, argv=0x7fffffffd1f8) at test.c:12
(gdb) p argv[0]
(gdb) f 1
12 in test.c
(gdb) p argv[0]
$1 = 0x7fffffffd56b "/root/testicx"
(gdb)
Great,
Can we close this thread?
This issue has been resolved and we will no longer respond to this thread. If you require additional assistance from Intel, please start a new thread. Any further interaction in this thread will be considered community only.
