Intel® C++ Compiler
vector size bug
xie__xie
When I am running this program, it will return wrong results, which are shown in the comments.
#include <iostream>
#include <vector>
int main()
  size_t n = 1000000000;
  std::vector<double> V(n);
  std::cout << V.size() << std::endl;
  // output: 1000000000
  // output: 18446744073635809792
  std::cout << V.capacity() << std::endl;
  return 0;
icc for Mac
Version 19.0.1.144 Build 20181018
Viet_H_Intel
these are results from my executions:
vahoang@orcsle147:/tmp$ icpc t.cpp
vahoang@orcsle147:/tmp$ ./a.out
1000000000
1000000000
1000000000
$ cat t.cpp
#include <iostream>
#include <vector>
int main()
  return 0;
vahoang@orcsle147:/tmp$ icc -V
xie__xie
But my results are still wrong:
iMac:Documents x$ icpc test.cpp
iMac:Documents x$ ./a.out
1000000000
1000000000
iMac:Documents x$ icc -V
Intel(R) C Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 19.0.1.144 Build 20181018
Copyright (C) 1985-2018 Intel Corporation.  All rights reserved.
xie__xie
The program will show the right results only with "icpc -O1 test.cpp" instruction. If I use '-O2' or the higher optimization option, the results will be wrong.
xie__xie
Could you tell me what are the specifications of your computer and your default optimization option?
1000000000
1000000000
1000000000
$ cat t.cpp
#include <iostream>
#include <vector>
int main()
  return 0;
Viet_H_Intel
I accidentally compiled at -O1; I am now seeing at -O2. I'll report this bug to our Developer.
Viet
Viet_H_Intel
I have submitted this bug: CMPLRIL0-30860
Viet
xie__xie
OK
Viet
