In my application, I have the following pattern occurring at many places:
loop_over_i(i)
do_something(i); // common for all loops
do_remaining_things(i);
The do_something part is common for most loops and so I am trying to extract it out with a class. However, the loop no longer vectorizes. A sample code is given below:
[cpp]#includeusing namespace std; class Loop { public: Loop(int max) : max_(max), count_(0), sqr_(0) { } void more() { ++count_ ; sqr_ = count_ * count_; } bool done() const { return count_ >= max_; } operator int() const { return count_; } int sqr() const { return sqr_; } private: int count_, max_, sqr_; }; int main() { int square[50]; // this loop vectorizes for (int i = 0; i < 50; ++i) { square = i*i; } // this loop doesn't vectorize for (Loop loop(50); !loop.done(); loop.more()) { square[loop] = loop.sqr(); } }[/cpp]
[cpp]How can I implement what I need in a way that the loop vectorizes?[/cpp]
loop_over_i(i)
When indexing square, elements i and i+1, i+2, ... are in adjacent memory locations, thus permitting vectorization. The compiler vectorization code will recognize loop syntax such as i<50 and ++i and can analyse that for candidate of vectorization.
When you declare the class Loop, and declare the member functions, the compiler does not have the necessary information in order to vectorize the loop. The compiler _potentially_ could vectorize the code if you inline the member functions. But having the !loop.done() may present a problem.
Also note that your more() function is computing the result for the element after the last element. Consider converting the more() to return a bool and remove the done function.
for(Loop loop(50); loop.more();)
where
inline bool more()
if(count_>= max_) return false;
++count_;
return true;
This syntax will not necessarily vectorize. It would depend on how aggressive the the compiler was at vectorization.
Jim Dempsey
loop_over_i(i)
loop_over_i(i)
where
inline bool more()
++count_;
return true;
Jim Dempsey
The fundamental problem you are experiencing is by making the code opaque by encapsulation with member functions and iterators you also tend to make it difficult, if not impossible for the compiler to vectorize or even to determinevectoizability ofthe code (as it chews through the data). This is the penalty you pay for progress. By using "old school" programming techniques such as array of like members of each object (as opposed to C++ arrays of objects of elements) the data layout favors vectorization. The requirements of the application would indicate the better of the two techniques. If you need the vectorization for performance then consider unpackaging the objects.
Jim
