I just reinstalled Windows 7 and moved to Visual Studio 2013. I first installed Visual Studio 2013 then Intel Parallel Studio XE 2013 with all updates for both products. Now when I create a new project and switch to the intel compiler ( Project -> Intel Composer XE 2013 SP 1-> use intel compiler I get the following error
1>------ Build started: Project: ConsoleApplication1, Configuration: Debug x64 ------
1> Source.cpp
1> warning #31001: The dll for reading and writing the pdb (for example, mspdb110.dll) could not be found on your path. This is usually a configuration error. Compilation will continue using /Z7 instead of /Zi, but expect a similar error when you link your program.
My C++ program is as follows
#include <iostream>
int main(int ac, char* av[])
std::cout << "Hello World!";
Anyone an idea what is going on?
Ps. Wish all of you a Merry Christmas!
how to deal with the problem
