Intel® C++ Compiler
7956 Discussions
warning #996: value of immediate argument to intrinsic is out of range
eos_pengwern
What does this message, obtained when compiling with /Qopt-report:3, signify. It occurs wherever my code has the line:
n = n << 8;
...where n is a 32-bit integer with zeros in its eight most significant bits?
Stephen.
Om_S_Intel
We can compile the following code segment without any issue:
c:\>type tstcase.cpp
int main()
int n[100];
int i;
for (i =0; i< 100; ++i)
n = i+1;
n = n << 8;
return 0;
c:\>icl /Qopt-report:3 tstcase.cpp
C:\>icl -V
Intel C++ Compiler XE for applications running on IA-32, Version 12.0.2.154 Build 20110112
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Om_S_Intel
int main()
int n[100];
int i;
n = i+1;
n = n << 8;
return 0;
C:\>icl -V
eos_pengwern
Ah, my silly fault... I had ARGB defined as an array of unsigned chars, and had forgotten to cast each block of four into an int32 before applying the shifts.
Thank you.
