Hello I am running Linux Ubuntu and am compiling using icpc (intel compiler), I want to get a shared library so I used the command:
icpc -o myShared.so -std=c++11 -shared -DSTDC_HEADERS -D __cplusplus=201103L -fpermissive -DPT_XX_DEV -fexceptions -frtti -DANDROID -w -fstack-protector -fPIE -fPIC -pie -O2 -D_FORTIFY_SOURCE=2 -Wformat -Wformat-security -I/home/admins/aaa/include -I/home/admins/bbb/include a.cpp b.cpp c.cpp $(LIBS)
the interesting thing that if I delete $(LIBS) I am getting the same warning, so in my opinion it probably means that it doesn't link at all....
ld: warning: cannot find entry symbol _start; defaulting to 0000000000007040
I read about this warning in previous topics, and I discovered that this warning connected to the entry point of the program, but as far as I understand - there shouldn't be entry point in shared library.
Does anyone have an idea how to resolve it?
Thank you very much!
Hi Vitaly,
You should not use -pie when generating shared library.
PIE: position-independent executable
PIC: position-independent code (shared library)
See below to help you understand the issue:
(Note: -shared and -fPIC/-fPIE should be used together, -pie and -fPIE/-fPIC should be used together)
$ cat temp.c #include <stdio.h> int main() {printf("hello\n");return 0;} $ icc temp.c -shared -fPIC -o out $ file out out: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked, not stripped $ ./out Segmentation fault (core dumped) $ icc temp.c -pie -fPIC -o out $ file out out: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.18, not stripped $ ./out hello $ icc temp.c -shared -fPIE -o out -pie ld: warning: cannot find entry symbol _start; defaulting to 0000000000000690 $ file out out: ELF 64-bit LSB shared object, x86-64, version 1 (SYSV), dynamically linked (uses shared libs), not stripped $ ./out -bash: ./out: /lib/ld64.so.1: bad ELF interpreter: No such file or directory $
When -pie is used, it will generate a executable in fact, which can run, so, "main" is required as entry point. -pie will told the compiler to generate an executable, and -shared will told the compiler to generate shared library, you are using these options together and it is a conflict. (Note: I've tried with GCC and it seems like there are some differences, but normally, -pie and -shared is a conflict, with ICC, when -pie is used before or after -shared, it will always take effect, with gcc, it seems the order matters, but the key point is that, using -pie and -shared together is incorrect.)
Shenghong
In my installations, gcc 5.2 (the current release but newer than the default version) doesn't support -pie, while gcc 6.0 (which I built from trunk) does. Thanks to Shenghong for beginning to explain these options.
It solved my problem.
thank you for your help!
Nice to know and this was a good question :)
_Kittur
