There seems to be a problem when compiling with the option /QxSSE... when linking to a DLL
when linking the same code to a EXE, the program speeds up by a factor of 2, which is great, but when compiling and linking the same sourcecode to a DLL the program gets slower by a factor of about 2.5 compared to using no /QxSSE.. statement.
without using /QxSSE, both EXE and DLL programms have the same speed.
Iam using the C++ Composer XE 2011 Integration for Microsoft Visual Studio* 2010, Version 12.0.1016.2010
i hope someone can help me here!
best regards,
Stefan
best regards,
Stefan
/arch:SSE2 is the default. If there still is a place in the documentation where /QxSSE is written (where SSE used to refer to the P-III ISA), that probably is a documentation bug. As far as I know, /QxSSE was never supported, as the old option /QxK was out of support by the time the QxSSE2 notation was introduced.
Are you comparing performance with and without basic vectorization (e.g. 32-bit /arch:IA32 vs. /QxSSE2 or -O1 vs. -O2)?
We may need a more specific example of what you are doing.
With a given .dll (not recompiled), the option you specify in the remainder of your code should not have a direct effect on performance of the .dll.
