Intel® C++ Compiler
7876 Discussions
where can we find command line options of mcpcom
Tanwar__Sandeep
Hi Folks,
I want to modify the command line options for mcpcom like -mGLOB etc but no idea where are these found.
This is related to a problem where I am trying to compile the binaries with check-pointers options but getting errors of undefined symbols for _intel_fast_memmove, __intel_sse2_strlen, __intel_sse2_strchr
Also the file libimf.so is not found even though I gave correct path during compilation and linking.
Any suggestions?
RahulV_intel
Hi Sandeep,
Could you share the following details:
  • OS and Intel C++ compiler version that you are currently working on.
  • Steps that you have followed, leading to the error.
-Rahul
Tanwar__Sandeep
Hi Rahul,
OS - RHEL 7.5
Compiler - icpc version 19.0.3.199 (gcc version 4.8.5 compatibility)
Compilation command line additional Parameters leading to this error - -rdynamic -check-pointers=rw -check-pointers-dangling=all -check-pointers-undimensioned -check-pointers-narrowing
RahulV_intel
Could you provide us the exact command that you have used and the subsequent error message you get after executing the command?
--Rahul
RahulV_intel
Hi Sandeep,
Just a quick reminder to provide the steps you've followed leading to the error and error log.
--Rahul
RahulV_intel
Hi Sandeep,
We are closing this thread. Kindly post a new query if your issue still persists.
--Rahul
