Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
win10 +visual studio2019+intel c++ 19.1 + 0xC0000001D Illegal Instruction
Jump to solution
I attempt  to use AVX512 instruction Set in VS 2019(intel c++ compiler),
when I used __mm512_load_espi512()  or __mm512_load_si512() fuction,
The system printed 0xC000001D :Illegal Instruction error,
I don't know the reason.
zmmintrin.h file was included.
Plz help me fix it,
Best reguards.
The code file is attached.
Accepted Solutions
Highlighted
Re:win10 +visual studio2019+intel c++ 19.1 + 0xC00...
Jump to solution
Your CPU only supports up to AVX2, which explained why you got "illegal instructions error".
Highlighted
Re: win10 +visual studio2019+intel c++ 19.1 + 0xC0000001D Illegal Instruction
Jump to solution
when I compile the code ,both _mm512_load_si512()  and  _mm512_store_si512 () function are undifined.
But the head file included.
I don't know why?
Highlighted
Jump to solution
You can use _mm512_load_epi32
They (_mm512_load_si512 and _mm512_load_epi32) use the same instruction vmovdqa32.
https://software.intel.com/sites/landingpage/IntrinsicsGuide/#text=_mm512_load&expand=3345,3304
Hmm? Paste of image from clipboard no longer working....
Jim Dempsey
Highlighted
Jump to solution
Do you know if you system supports AVX-512?
Highlighted
Jump to solution
hi,Mr.Jim
Thank you very much for your reply.
Also,I used the instruction (_mm512_load_epi32),AVX2 instructions running good, additionally, I tested the other AVX512 instructions , it's the same issue.That doesn't seem to be the reason.
Highlighted
Re: Re:win10 +visual studio2019+intel c++ 19.1 + 0xC00...
Jump to solution
I don't know the system requirements of the AVX-512.
My Notebook system is Win10/CPU core is intel i7-10750H/memory is 16G.
Pls help check if it support ?Thanks so much.
Highlighted
Jump to solution
Highlighted
Jump to solution
What's the system minimum requirements?
^_^
Highlighted
Jump to solution
Hi Stephen,
As already mentioned in the above reply by Viet, your processor does not support AVX-512. For more details, you can refer to the below link to get more details.
https://ark.intel.com/content/www/us/en/ark/products/201837/intel-core-i7-10750h-processor-12m-cache...
Check Instruction Set Extensions sections.
Warm Regards,
Abhishek
Highlighted
Jump to solution
hi,Abhishek
Thanks for your detailed reply, and I got it .
Maybe I have to buy a new PC to solve this question.
^_^
stephen
Highlighted
Jump to solution
As your issue is resolved can we close this thread?
You are always welcome to post a new thread if you have any issues.
Warm Regards,
Abhishek
