When using ccache and compilng files with the -x c option, ccache first generates the preprocessed file then runs the intel compiler with -x cpp-output. According to the docs, it should treat the preprocessed file as a C file (not C++), but I'm getting void * casting errors. I don't see the same error with gcc, this looks like a bug?
I'm using Intel 13.1.1 20130313 on Fedora 14 64 bit.
Update : I was using icpc not icc. icpc is the equivalent of g++ (http://software.intel.com/en-us/forums/topic/308711). Looks like icpc doesn't obey -x cpp-output
@Sergey : Thanks, but those are windows compiler options and I'm using linux.
Reproducable case :
contents of main.i
# 1 "main.c"
int main()
void * vp = 0;
int * p = vp;
return 0;
}Command to run, I expected success :
icpc13 -c -x cpp-output -o main.o main.i
main.c(4): error: a value of type "void *" cannot be used to initialize an entity of type "int *"
int * p = vp;
^compilation aborted for main.i (code 2)
The above command works with icc13 instead of icpc13.
