Community
cancel
Showing results for
Search instead for
Did you mean:
Intel_C_Intel
xilib: error: could not write to argument file 'C:DOCUME~1'
Hi,everyone!
I got some errors when Icompiling my C++ program with 8.0 version.
The error is following:
xilib: error: couldn't open multi-file optimizations object list
There is enough space left in C: and C:DOCUME~1 is writeable. What's the problem?
How is xilib being invoked? Are you doing it directly? What is the command line? It could be the case that this argument filenamed in the message is write-protected? What is the name of the argument file?
Max
Intel_C_Intel
Thanks, Max. The problem is solved. It's because there are chinese character in $TEMPand $TMP. I set them to another directory and it works.
