Intel® C++ Compiler
xilib issue with Intel C++ XE
jwitmann
I have enabled -qipo for compiling my entire project and at the time of creating the library here is what i get:
xilib.exe -qipo -lib -OUT:lib\\ecc_private.lib obj\\ecc_common.obj obj\\ecc_sign.obj obj\\int128.obj obj\\mstdlib.obj obj\\random.obj obj\\base64m.obj obj\\primeec.obj obj\\primefld.obj obj\\sha1.o
bj obj\\sha512.obj obj\\win32_rtos.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\175445_ipo\\ecc_common.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\175447_ipo\\ecc_sign.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\175449_ipo\\int128.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754411_ipo\\mstdlib.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754413_ipo\\random.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754415_ipo\\base64m.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754417_ipo\\primeec.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754419_ipo\\primefld.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754421_ipo\\sha1.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754423_ipo\\sha512.obj
ipo: remark #11006: generating object file C:\\DOCUME~1\\jerome\\LOCALS~1\\Temp\\1754425_ipo\\win32_rtos.obj
xilib: executing 'lib'
Microsoft Library Manager Version 7.00.9466
Copyright (C) Microsoft Corporation. All rights reserved.
LIB : fatal error LNK1104: cannot open file '-OUT:lib\\ecc_private.lib'
As you can see the command line has some extra garbage in front.
The exact version is as follow:
Intel Compiler linker driver for applications running on IA-32, Version 12.0.2.154 Build 20110112
Copyright (C) 1985-2011 Intel Corporation. All rights reserved.
Also, this problem doesn't exists with ICL v11.0.
Jerome
Om_S_Intel
I think there is problem in the command line. I can run xilink without any issue.
c:\>xilink /OUT:Intel12BugPlugin.dll /DLL "kernel32.lib" "user32.lib" "gdi32.lib" "winspool.lib" "comdlg32.lib" "advapi32.lib" "shell32.lib" "ole32.lib" "oleaut32.lib" "uuid.lib" "odbc32.lib" "odbccp32.lib" Plugin.obj
xilink: executing 'link'
Microsoft Incremental Linker Version 10.00.30319.01
/DLL
kernel32.lib
user32.lib
gdi32.lib
winspool.lib
comdlg32.lib
advapi32.lib
shell32.lib
ole32.lib
oleaut32.lib
uuid.lib
odbc32.lib
odbccp32.lib
ipo_48085obj.obj
Creating library Intel12BugPlugin.lib and object Intel12BugPlugin.exp
jwitmann
Well, the problem is with XILIB not xilink, and I was creating a LIB not a DLL, your test hardly compares :).
Also, a command line issue would be doubtfull... the same work with v11.0 without any problem or changes.
Om_S_Intel
I tried xilib. It seems to work.
c:\>xilib -lib /OUT:plugin.lib Plugin.obj Caller.obj
Microsoft Library Manager Version 10.00.30319.01
/OUT:plugin.lib
C:\Users\opsachan\AppData\Local\Temp\64365_ipo\Plugin.obj
C:\Users\opsachan\AppData\Local\Temp\64367_ipo\Caller.obj
jwitmann
This is rather interresting - I changed the dev env from my WDK to VS2010 command line, and now it works. Tried my VS2008 works as well. Which lead me to change the default LINK version invoked (I have too many DDK/SDK), and starting with v8.00 it works fine.
Sorry for the inconvenience, I guess it was a config issue of some sort (weird).
Jerome
Om_S_Intel
I am happy to learn taht the issue is resolved.
