I am using Intel Composer XE SP1 Update 4 for Windows.
To compile my project, I use :
call "%VS110COMNTOOLS%vsvars32.bat" msbuild /v:d /p:VisualStudioVersion=11.0;Configuration=Release Marvel.Maths.AvxCalculationNativeKernels.vcxproj
- vsvars32.bat : configure env for VS2012 (I also have VS2010 & VS2013 on my desktop)
- VisualStudioVersion=11.0 : ensure Visual Studio 2012 env is configured (cf. http://blogs.msdn.com/b/webdev/archive/2012/08/22/visual-studio-project-compatability-and-visualstud...
With this setup, if I run msbuild command again, xilink is called :
All outputs are up-to-date.
Forcing rebuild of all source files due to a change in the command line since the last build.
(full detailed log is attached)
I cannot find any difference between both command lines (starting from the /OUT parameter)
Why is xilink rebuiling my project?
Thanks in advance for your help
Vianney
Would it be possible to share the project files to investigate further ?
Reddy
Hello Reddy,
I have attached a minimalist project that reproduces the problem.
To proceed, just run :
Marvel\Maths\AvxCalculationNativeKernels\build.cmd
The batch will :
- Rebuild from scratch
- Build incrementally with details and save the build log
- Grep for "change in the command line" in the build.log.
You will also find the log generated on my desktop in Marvel\Maths\AvxCalculationNativeKernels\msbuild.log.
Vianney
One of my colleague just tested my demo project with XE 2015, and we still have the same rebuild problem.
We also checked that the log has a line saying "Building with Intel(R) C++ Compiler XE 15.0".
Thanks for sharing the demo project, I will investigate and update you.
Reddy
I suspect the difference of quotes for xilink.exe in the first command and tracker command might be causing the issue. However this issue is escalated to engineering team, I will check status and keep update you.
Reddy
Thanks Reddy, waiting for your feedback.
[3rd version of this comment]
If I update my ard.ProjectCompileOptions.props file to force BasePlatformToolset :
<PlatformToolset Condition="'$(VisualVersion)' == 'vc9'">v90</PlatformToolset> <PlatformToolset Condition="'$(VisualVersion)' == 'vc10'">v100</PlatformToolset> <!-- Fix begin --> <BasePlatformToolset Condition="'$(UseIntelCppCompiler)' == 'true'">$(PlatformToolset)</BasePlatformToolset> <!-- Fix end --> <PlatformToolset Condition="'$(UseIntelCppCompiler)' == 'true'">Intel C++ Compiler XE 14.0</PlatformToolset>
The compiler complains about a missing target :
C:\Program Files (x86)\MSBuild\Microsoft.Cpp\v4.0\V110\Platforms\Win32\PlatformToolsets\Intel C++ Compiler XE 14.0\Microsoft.Cpp.Win32.Intel C++ Compiler XE 14.0.targets(1172,7): error MSB4057: The target "ComputeLegacyManifestEmbedding" does not exist in the project.
If I add this target in my project :
<Target Name="ComputeLegacyManifestEmbedding" Condition="'$(BasePlatformToolset)' == 'v100'" />
It now works in x86 (no more rebuild).
Unfortunately, it fails in x64 (tracker event missing) :
TRACKER : error TRK0002: Failed to execute command: ""C:\Program Files (x86)\Intel\Composer XE 2013 SP1\bin\Intel64\xilink.exe" @C:\Users\vphilipp061807\AppData\Local\Temp\tmp889edd048c194b4b85d99ee8bd51764a.rsp". The operation identifier is not valid.
Vianney
I'm back from holidays. Any update on this?
Removed erroneous comment.
Dear Customer,
FYI. This issue should have been fixed and Please verify with v15.0 update 3 release which is available at https://registrationcenter.intel.com/.
Reddy
