I was trying to offload some computation to GFX, and process "xilink.exe" crashes and output in visual studio says:
2>xilink: : error #10014: problem during multi-file optimization compilation (code -1073740777) 2>xilink: : error #10014: problem during multi-file optimization compilation (code -1073740777)
I thought we are in 21st century, so cryptic error codes were so popular in early 90's...
err, actually mcpcom.exe crashes.
any update on this issue?
Are you using /Qipo compiler option when building your GFX offload code and does the offload code/function span across multiple compilation units in your application? Is it possible to share the code for further investigation?
Thanks and Regards
Anoop
I am not building with GFX offload, and I have an issue with the same configuration with URL https://software.intel.com/en-us/forums/topic/56213 ....
