Intel® C++ Compiler
xmmintrin.h
Burlen_L_
I'm having an issue with icc on linux, it's using xmmintrin.h from the gcc install. I've tested on 3 systems, each of these has different icc gcc versions :-). On 2 of the systems the build fails, the other it does not. I'm wondering if in newer versions of icc, icc searches its own directories for files before gcc's? or if icc always finds gcc's xmmintin.h first, and on the system where I don't have build errors, it just so happens to be that gcc's xmminrin.h is compatible with the one belonging to icc?
I've been working around by appending -I$INTEL_ROOT/include/{intel64,ia32}. but I don't want to do this if intel automatically does this in it's newer compilers. I want to find a reliable solution for all intel compiler versions.
Burlen
KitturGanesh
Hi Burlen, Well, looking at the log I find the following: The culprit is: --sys_include \ /opt/intel/Compiler/11.1/038/bin/include This means that the headers are not being searched in /opt/intel/Compiler/11.1/038/Compiler/include/intel64 and the driver is using the flat structure to attempt to find the directories in question. If you had installed the compiler correctly, there should be both the /opt/intel/Compiler/11.1/038/Compiler/include and the /opt/intel/Compiler/11.1/038/Compiler/lib/intel64 directories. Sourcing the iccvars.sh ensures the compiler/lib path is set. And, if the compiler/lib and compiler/include paths are not found in the installed directory it assumes a flat include & lib structure and uses those paths. So, please ensure that the /opt/intel/Compiler/11.1/038/Compiler/include/intel64 and /opt/intel/Compiler/11.1/038/Compiler/lib/intel64 are on the system. And set the following path: export CPATH=/opt/intel/Compiler/11.1/038/Compiler/include/intel64:$CPATH to guarantee that the correct compiler include is used. Regards, Kittur
TimP
If you don't interfere with the way icc is installed, it will use only its own implementations of *mmintrin.h, while gcc will use its own. Attempting to mix them is likely to cause trouble. Most of the effects of these are local to the compilation units. Those which aren't local (definition of data structures) should be compatible. Possibly a degree of incompatibility comes from the way icc expects you to include the top level immintrin.h and rely on it to include the lower level ones such as xmmintrin.h, while gcc is more oriented toward use of the specific include file which matches your intrinsics.
Burlen_L_
I'm using the existing icc installs at hpc centers NERSC,NICS, and TACC. I had assumed that icc was installed correctly on all. however it sounds like you're saying the install is broken if icc ends up using gcc's *mmintin? Are you sure about this?
TimP
I suppose, if you include some version of ?mmintrin.h which isn't present in icc's include directory, one from gcc might be used. In that case, it's not the install which is broken. As I mentioned, icc doesn't expect to see #include "xmmintrin.h", it wants the latest version which includes the others as needed. I wouldn't bet against any of those people installing icc correctly.
JenniferJ
also make sure you run icc or icpc after source compilervars.sh. so the compiler env is setup properly.
Burlen_L_
Ufortunately, using immintrin.h instead of xmmintrin.h doesn't make a difference. icc still finds gcc's version of xmmintrin.h.
Burlen_L_
One these systems one would load an environment module to configure the compiler eg. "module load intel". Just to be sure I tried "source /opt/intel/Compiler/11.1/038/bin/iccvars.sh intel64" and it didn't help.
SergeyKostrov
Valued Contributor II
>>...On 2 of the systems the build fails, the other it does not. I'm wondering if in newer versions of icc, icc searches its own directories for files before gcc's? . There are two C++ compiler command line options ( /L and /l ) that control the order of a search for header files in directories. Did you consider it?
SergeyKostrov
>>...Ufortunately, using immintrin.h instead of xmmintrin.h doesn't make a difference... . These two headers are very different and they can not be used as a substitution of one by another: . - xmmintrin.h - is a Principal header file for Streaming SIMD Extensions intrinsics - immintrin.h - is Intel(R) AVX compiler intrinsics
Burlen_L_
those are linker options...?
KitturGanesh
Hi, If you have sourced the icc script "compilervars.sh intel64", it should have set up the compiler include/lib paths. The compiler (icc) driver tries to formulate the include search path based on install directory information. Basically: 1) Intel header path 2) gcc versioned header path 3) system header path in that order. Sounds to me that here is a problem with the installation of icc. The user should not have to explicitly add the Intel specific header directory on the command line. The driver is dependent on seeing that both the compiler/include/intel64 directory and compiler/lib/intel64 directory is found before it sets up its directory search paths. If those aren't found, the driver reverts to a flat bin include lib search path structure. Compile with the option "-#x" and attach the output so I can pass that to our developers for further investigation? Regards, Kittur
Burlen_L_
... and intel's intrinsics reference documentation no where mentions not including any of these directly. perhaps it's a good idea to use the higher level include, but if it were necessary I think that it would be more clearly specified in the documentation...
Burlen_L_
There's no file named "compilervars.sh" , however there are a number of files named like "${TOOL}vars.sh", for ex. "iccvars.sh". After sourcing this icc still finds gcc's copy of the intrinsics ...
Kittur
-#x output from compilation of a single cxx class follows. Thanks for looking at this! [bash] /opt/intel/Compiler/11.1/038/bin/intel64/mcpcom \ -_g \ -mP3OPT_inline_alloca \ -D__HONOR_STD \ -D__ICC=1110 \ -D__INTEL_COMPILER=1110 \ -D_MT \ "-_Asystem(unix)" \ -D__ELF__ \ "-_Acpu(x86_64)" \ "-_Amachine(x86_64)" \ -D__INTEL_COMPILER_BUILD_DATE=20090511 \ -D__PTRDIFF_TYPE__=long \ "-D__SIZE_TYPE__=unsigned long" \ -D__WCHAR_TYPE__=int \ "-D__WINT_TYPE__=unsigned int" \ "-D__INTMAX_TYPE__=long int" \ "-D__UINTMAX_TYPE__=long unsigned int" \ -D__PIC__ \ -D__pic__ \ -D__LONG_MAX__=9223372036854775807L \ -D__QMSPP_ \ -D__NO_MATH_INLINES \ -D__NO_STRING_INLINES \ -D__NO_INLINE__ \ -D__GNUG__=4 \ -D__GNUC__=4 \ -D__GNUC_MINOR__=3 \ -D__GNUC_PATCHLEVEL__=0 \ -D__NO_INLINE__ \ -D__i686 \ -D__i686__ \ -D__pentiumpro \ -D__pentiumpro__ \ -D__pentium4 \ -D__pentium4__ \ -D__SSE2__ \ -D__tune_pentium4__ \ -D__MMX__ \ -D__SSE__ \ -D__LP64__ \ -D_LP64 \ -D_GNU_SOURCE=1 \ -U__DEPRECATED \ -D__GXX_WEAK__=1 \ -D__GXX_ABI_VERSION=1002 \ "-D__USER_LABEL_PREFIX__= " \ -D__REGISTER_PREFIX__= \ -D__INTEL_RTTI__ \ -D__EXCEPTIONS=1 \ -D__unix__ \ -D__unix \ -D__linux__ \ -D__linux \ -D__gnu_linux__ \ -B \ -Dunix \ -Dlinux \ -D__x86_64 \ -D__x86_64__ \ -_k \ -_8 \ -_l \ -_a \ -_b \ --gnu_version=430 \ -_W5 \ --gcc-extern-inline \ -p \ --bool \ -tused \ -mGLOB_eh_linux \ -x \ --mspp \ --multibyte_chars \ --diag_suppress=279,1170,161,177 \ --honor_f32_conversion=1 \ --honor_f64_conversion=1 \ -DSciberQuestToolKit_EXPORTS \ -DMPICH_IGNORE_CXX_SEEK \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/KWSys \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/KWSys \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/System \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/System \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Transforms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Transforms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/DataModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/DataModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ExecutionModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ExecutionModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ComputationalGeometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ComputationalGeometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/zlib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/zlib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Legacy \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Legacy \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/HashSource \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/HashSource \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/FlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/FlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/DICOMParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/DICOMParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO/vtkmetaio \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MetaIO \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/jpeg \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/jpeg \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/png \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/png \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/tiff \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/tiff \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Extraction \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Extraction \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/expat \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/expat \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XMLParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XMLParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MaterialLibrary \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MaterialLibrary \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/freetype \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/freetype \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/ftgl \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeType \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeType \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/ParseOGLExt \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/ParseOGLExt \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/EncodeString \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/EncodeString \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/OpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/OpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeTypeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeTypeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Volume \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Volume \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/VolumeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/VolumeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library/VisItLib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Database \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Pipeline \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Plotter \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/comm \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/expr \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/icons \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/parser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/plugin \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/proxybase \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/state \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/utility \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/plugin \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/state \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/utility \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Database \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Ghost \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/MetaData \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/SIL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/VisWindow/VisWindow \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/IVP \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/AbstractFilters \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Data \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Pipeline \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sinks \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/full \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/lightweight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/boost_1_46_1 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/TestDriver \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/TestDriver \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Infovis/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Infovis/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/MathText \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/MathText \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Charts/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Charts/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/gl2ps \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/gl2ps \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/GL2PS \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/GL2PS \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Export \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Export \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2/vtklibxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/libxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Infovis \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Infovis \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Modeling \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Modeling \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Style \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Style \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Annotation \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Annotation \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Widgets \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Widgets \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerStream \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerStream \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Programmable \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Programmable \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/PythonSupport \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/PythonSupport \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/Common \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/Common \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/MPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/MPI \ -I/opt/sgi/mpt/mpt-2.04/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Tools \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Tools \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/WrapClientServer \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/WrapClientServer \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf/vtkprotobuf/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/protobuf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Domains/Chemistry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Domains/Chemistry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Generic \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Generic \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/HyperTree \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/HyperTree \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelFlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelFlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Fourier \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Fourier \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/alglib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/alglib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Statistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Statistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Imaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Imaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelImaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelImaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelMPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelMPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelStatistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelStatistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Texture \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Texture \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5/vtkhdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/EnSight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/EnSight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf/vtknetcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/exodusII \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/exodusII \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Exodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Exodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Import \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Import \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/MPIImage \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/MPIImage \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/oggtheora \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/oggtheora \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Movie \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Movie \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/NetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/NetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/PLY \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/PLY \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelExodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelExodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/LSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/LSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelLSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelLSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelNetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelNetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases/AvtAlgorithms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/databases \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Morphological \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Morphological \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT/vtkicet/src/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT/vtkicet/src/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Label \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Label \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/HybridOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/HybridOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/LOD \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/LOD \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/ProcessXML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/ProcessXML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/SMApplication \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/SMApplication \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/CoProcessor \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/CoProcessor \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/GenericBridge \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/GenericBridge \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Python \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Python \ -I/sw/analysis/python/2.7.1/sles11.1_intel11.1/include/python2.7 \ -I/sw/analysis/osmesa/7.5.1/sles11.1_intel11.1.038/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/eigen-3.0.3/eigen-eigen-3.0.3 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Plugins/SciberQuestToolKit \ --sys_include \ /opt/intel/Compiler/11.1/038/ipp/em64t/include \ --sys_include \ /opt/intel/Compiler/11.1/038/mkl/include \ --sys_include \ /opt/intel/Compiler/11.1/038/tbb/include \ --sys_include \ /sw/analysis/python/2.7.1/sles11.1_intel11.1/include \ --sys_include \ /opt/intel/Compiler/11.1/038/include \ --sys_include \ /opt/intel/Compiler/11.1/038/mkl/include \ --sys_include \ /opt/intel/Compiler/11.1/038/ipp/em64t/include \ --sys_include \ /opt/intel/Compiler/11.1/038/tbb/include \ --sys_include \ /opt/sgi/mpt/mpt-2.04/include \ --sys_include \ /usr/include/c++/4.3 \ --sys_include \ /usr/include/c++/4.3/x86_64-suse-linux \ --sys_include \ /usr/include/c++/4.3/backward \ --sys_include \ /opt/intel/Compiler/11.1/038/bin/include \ --sys_include \ /usr/local/include \ --sys_include \ /usr/include \ --sys_include \ /usr/lib64/gcc/x86_64-suse-linux/4.3/include \ --bool \ -mP1OPT_version=11.1-intel64 \ -mGLOB_diag_enable_disable=D:279,D:1170,D:161,D:177 \ -mGLOB_diag_file=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.diag \ -mP1OPT_print_version=FALSE \ -mP3OPT_use_mspp_call_convention \ -mCG_use_gas_got_workaround=F \ -mP2OPT_align_option_used=TRUE \ "-mGLOB_options_string=-I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/KWSys -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/KWSys -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/System -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/System -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Transforms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Transforms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/DataModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/DataModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ExecutionModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ExecutionModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ComputationalGeometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ComputationalGeometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/zlib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/zlib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Legacy -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Legacy -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/HashSource -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/HashSource -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/FlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/FlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/DICOMParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/DICOMParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO/vtkmetaio -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MetaIO -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/jpeg -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/jpeg -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/png -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/png -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/tiff -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/tiff -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Extraction -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Extraction -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/expat -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/expat -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XMLParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XMLParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MaterialLibrary -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MaterialLibrary -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/freetype -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/freetype -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/ftgl -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeType -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeType -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/ParseOGLExt -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/ParseOGLExt -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/EncodeString -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/EncodeString -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/OpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/OpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeTypeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeTypeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Volume -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Volume -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/VolumeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/VolumeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library/VisItLib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Database -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Pipeline -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Plotter -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/comm -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/expr -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/icons -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/parser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/plugin -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/proxybase -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/state -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/utility -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/plugin -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/state -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/utility -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Database -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Ghost -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/MetaData -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/SIL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/VisWindow/VisWindow -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/IVP -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/AbstractFilters -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Data -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Pipeline -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sinks -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/full -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/lightweight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/boost_1_46_1 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/TestDriver -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/TestDriver -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Infovis/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Infovis/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/MathText -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/MathText -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Charts/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Charts/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/gl2ps -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/gl2ps -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/GL2PS -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/GL2PS -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Export -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Export -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2/vtklibxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/libxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Infovis -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Infovis -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Modeling -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Modeling -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Style -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Style -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Annotation -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Annotation -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Widgets -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Widgets -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerStream -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerStream -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Programmable -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Programmable -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/PythonSupport -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/PythonSupport -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/Common -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/Common -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/MPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/MPI -I/opt/sgi/mpt/mpt-2.04/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Tools -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Tools -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/WrapClientServer -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/WrapClientServer -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf/vtkprotobuf/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/protobuf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Domains/Chemistry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Domains/Chemistry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Generic -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Generic -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/HyperTree -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/HyperTree -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelFlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelFlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Fourier -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Fourier -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/alglib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/alglib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Statistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Statistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Imaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Imaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelImaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelImaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelMPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelMPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelStatistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelStatistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Texture -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Texture -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5/vtkhdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/EnSight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/EnSight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf/vtknetcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/exodusII -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/exodusII -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Exodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Exodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Import -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Import -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/MPIImage -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/MPIImage -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/oggtheora -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/oggtheora -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Movie -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Movie -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/NetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/NetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/PLY -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/PLY -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelExodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelExodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/LSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/LSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelLSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelLSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelNetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelNetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases/AvtAlgorithms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/databases -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Morphological -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Morphological -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT/vtkicet/src/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT/vtkicet/src/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Label -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Label -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/HybridOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/HybridOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/LOD -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/LOD -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/ProcessXML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/ProcessXML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/SMApplication -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/SMApplication -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/CoProcessor -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/CoProcessor -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/GenericBridge -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/GenericBridge -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Python -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Python -I/sw/analysis/python/2.7.1/sles11.1_intel11.1/include/python2.7 -I/sw/analysis/osmesa/7.5.1/sles11.1_intel11.1.038/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/eigen-3.0.3/eigen-eigen-3.0.3 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Plugins/SciberQuestToolKit -#x -DSciberQuestToolKit_EXPORTS -DMPICH_IGNORE_CXX_SEEK -Wno-deprecated -wd279,1170,161,177 -g -fPIC -o CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o -c" \ -mGLOB_position_independent_code \ -mGLOB_preemption_model=3 \ -mGLOB_cxx_limited_range=FALSE \ -mP3OPT_emit_line_numbers \ -mP2OPT_suppress_unreferenced_locals=FALSE \ -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \ -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \ -mGLOB_as_output_backup_file_name=/tmp/icpc1Ts9GAas_.s \ -mIPOPT_activate \ -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \ -mGLOB_nonstandard_lib \ -mGLOB_maintain_errno \ -mGLOB_noinline_intrinsics \ -mGLOB_use_base_pointer \ -mGLOB_extended_instructions=0x8 \ -mIPOPT_ninl_limit=0 \ -mIPOPT_ninl_user_level=0 \ -mIPOPT_args_in_regs=0 \ -mIPOPT_args_in_regs=0 \ -mPGOPTI_value_profile_use=T \ -mP2OPT_gen_linux_const_pooling=FALSE \ -mGLOB_opt_level=0 \ -mIPOPT_obj_output_file_name=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o \ -mGLOB_linker_version=2.20.0.20100122-0.7.9 \ -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \ -mGLOB_obj_output_file=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o \ -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_C_PLUS_PLUS \ -mP1OPT_source_file_name=/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx \ /sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(105): error: identifier "__builtin_ia32_addss" is undefined return (__m128) __builtin_ia32_addss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(111): error: identifier "__builtin_ia32_subss" is undefined return (__m128) __builtin_ia32_subss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(117): error: identifier "__builtin_ia32_mulss" is undefined return (__m128) __builtin_ia32_mulss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(123): error: identifier "__builtin_ia32_divss" is undefined return (__m128) __builtin_ia32_divss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(129): error: identifier "__builtin_ia32_sqrtss" is undefined return (__m128) __builtin_ia32_sqrtss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(135): error: identifier "__builtin_ia32_rcpss" is undefined return (__m128) __builtin_ia32_rcpss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(141): error: identifier "__builtin_ia32_rsqrtss" is undefined return (__m128) __builtin_ia32_rsqrtss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(147): error: identifier "__builtin_ia32_minss" is undefined return (__m128) __builtin_ia32_minss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(153): error: identifier "__builtin_ia32_maxss" is undefined return (__m128) __builtin_ia32_maxss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(161): error: identifier "__builtin_ia32_addps" is undefined return (__m128) __builtin_ia32_addps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(167): error: identifier "__builtin_ia32_subps" is undefined return (__m128) __builtin_ia32_subps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(173): error: identifier "__builtin_ia32_mulps" is undefined return (__m128) __builtin_ia32_mulps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(179): error: identifier "__builtin_ia32_divps" is undefined return (__m128) __builtin_ia32_divps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(185): error: identifier "__builtin_ia32_sqrtps" is undefined return (__m128) __builtin_ia32_sqrtps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(191): error: identifier "__builtin_ia32_rcpps" is undefined return (__m128) __builtin_ia32_rcpps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(197): error: identifier "__builtin_ia32_rsqrtps" is undefined return (__m128) __builtin_ia32_rsqrtps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(203): error: identifier "__builtin_ia32_minps" is undefined return (__m128) __builtin_ia32_minps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(209): error: identifier "__builtin_ia32_maxps" is undefined return (__m128) __builtin_ia32_maxps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(217): error: identifier "__builtin_ia32_andps" is undefined return __builtin_ia32_andps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(223): error: identifier "__builtin_ia32_andnps" is undefined return __builtin_ia32_andnps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(229): error: identifier "__builtin_ia32_orps" is undefined return __builtin_ia32_orps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(235): error: identifier "__builtin_ia32_xorps" is undefined return __builtin_ia32_xorps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(245): error: identifier "__builtin_ia32_cmpeqss" is undefined return (__m128) __builtin_ia32_cmpeqss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(251): error: identifier "__builtin_ia32_cmpltss" is undefined return (__m128) __builtin_ia32_cmpltss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(257): error: identifier "__builtin_ia32_cmpless" is undefined return (__m128) __builtin_ia32_cmpless ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(265): error: identifier "__builtin_ia32_cmpltss" is undefined __builtin_ia32_cmpltss ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(263): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(275): error: identifier "__builtin_ia32_cmpless" is undefined __builtin_ia32_cmpless ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(273): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(283): error: identifier "__builtin_ia32_cmpneqss" is undefined return (__m128) __builtin_ia32_cmpneqss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(289): error: identifier "__builtin_ia32_cmpnltss" is undefined return (__m128) __builtin_ia32_cmpnltss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(295): error: identifier "__builtin_ia32_cmpnless" is undefined return (__m128) __builtin_ia32_cmpnless ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(303): error: identifier "__builtin_ia32_cmpnltss" is undefined __builtin_ia32_cmpnltss ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(301): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(313): error: identifier "__builtin_ia32_cmpnless" is undefined __builtin_ia32_cmpnless ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(311): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(321): error: identifier "__builtin_ia32_cmpordss" is undefined return (__m128) __builtin_ia32_cmpordss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(327): error: identifier "__builtin_ia32_cmpunordss" is undefined return (__m128) __builtin_ia32_cmpunordss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(337): error: identifier "__builtin_ia32_cmpeqps" is undefined return (__m128) __builtin_ia32_cmpeqps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(343): error: identifier "__builtin_ia32_cmpltps" is undefined return (__m128) __builtin_ia32_cmpltps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(349): error: identifier "__builtin_ia32_cmpleps" is undefined return (__m128) __builtin_ia32_cmpleps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(355): error: identifier "__builtin_ia32_cmpgtps" is undefined return (__m128) __builtin_ia32_cmpgtps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(361): error: identifier "__builtin_ia32_cmpgeps" is undefined return (__m128) __builtin_ia32_cmpgeps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(367): error: identifier "__builtin_ia32_cmpneqps" is undefined return (__m128) __builtin_ia32_cmpneqps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(373): error: identifier "__builtin_ia32_cmpnltps" is undefined return (__m128) __builtin_ia32_cmpnltps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(379): error: identifier "__builtin_ia32_cmpnleps" is undefined return (__m128) __builtin_ia32_cmpnleps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(385): error: identifier "__builtin_ia32_cmpngtps" is undefined return (__m128) __builtin_ia32_cmpngtps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(391): error: identifier "__builtin_ia32_cmpngeps" is undefined return (__m128) __builtin_ia32_cmpngeps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(397): error: identifier "__builtin_ia32_cmpordps" is undefined return (__m128) __builtin_ia32_cmpordps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(403): error: identifier "__builtin_ia32_cmpunordps" is undefined return (__m128) __builtin_ia32_cmpunordps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(412): error: identifier "__builtin_ia32_comieq" is undefined return __builtin_ia32_comieq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(418): error: identifier "__builtin_ia32_comilt" is undefined return __builtin_ia32_comilt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(424): error: identifier "__builtin_ia32_comile" is undefined return __builtin_ia32_comile ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(430): error: identifier "__builtin_ia32_comigt" is undefined return __builtin_ia32_comigt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(436): error: identifier "__builtin_ia32_comige" is undefined return __builtin_ia32_comige ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(442): error: identifier "__builtin_ia32_comineq" is undefined return __builtin_ia32_comineq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(448): error: identifier "__builtin_ia32_ucomieq" is undefined return __builtin_ia32_ucomieq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(454): error: identifier "__builtin_ia32_ucomilt" is undefined return __builtin_ia32_ucomilt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(460): error: identifier "__builtin_ia32_ucomile" is undefined return __builtin_ia32_ucomile ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(466): error: identifier "__builtin_ia32_ucomigt" is undefined return __builtin_ia32_ucomigt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(472): error: identifier "__builtin_ia32_ucomige" is undefined return __builtin_ia32_ucomige ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(478): error: identifier "__builtin_ia32_ucomineq" is undefined return __builtin_ia32_ucomineq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(486): error: identifier "__builtin_ia32_cvtss2si" is undefined return __builtin_ia32_cvtss2si ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(503): error: identifier "__builtin_ia32_cvtss2si64" is undefined return __builtin_ia32_cvtss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(510): error: identifier "__builtin_ia32_cvtss2si64" is undefined return __builtin_ia32_cvtss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(519): error: identifier "__builtin_ia32_cvtps2pi" is undefined return (__m64) __builtin_ia32_cvtps2pi ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(532): error: identifier "__builtin_ia32_cvttss2si" is undefined return __builtin_ia32_cvttss2si ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(548): error: identifier "__builtin_ia32_cvttss2si64" is undefined return __builtin_ia32_cvttss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(555): error: identifier "__builtin_ia32_cvttss2si64" is undefined return __builtin_ia32_cvttss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(564): error: identifier "__builtin_ia32_cvttps2pi" is undefined return (__m64) __builtin_ia32_cvttps2pi ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(577): error: identifier "__builtin_ia32_cvtsi2ss" is undefined return (__m128) __builtin_ia32_cvtsi2ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(593): error: identifier "__builtin_ia32_cvtsi642ss" is undefined return (__m128) __builtin_ia32_cvtsi642ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(600): error: identifier "__builtin_ia32_cvtsi642ss" is undefined return (__m128) __builtin_ia32_cvtsi642ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: identifier "__v2si" is undefined return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: expected a ")" return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: identifier "__builtin_ia32_cvtpi2ps" is undefined return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(622): error: identifier "__v4hi" is undefined __v4hi __sign; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(623): error: identifier "__v2si" is undefined __v2si __hisi, __losi; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: identifier "__v4hi" is undefined __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: expected a ")" __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: identifier "__builtin_ia32_pcmpgtw" is undefined __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(632): error: identifier "__v2si" is undefined __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(632): error: expected a ";" __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(633): error: expected a ";" __losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(637): error: identifier "__builtin_ia32_cvtpi2ps" is undefined __r = __builtin_ia32_cvtpi2ps (__r, __hisi); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(638): error: identifier "__builtin_ia32_movlhps" is undefined __r = __builtin_ia32_movlhps (__r, __r); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(648): error: identifier "__v2si" is undefined __v2si __hisi, __losi; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(652): error: identifier "__v2si" is undefined __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(652): error: expected a ";" __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(653): error: expected a ";" __losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(657): error: identifier "__builtin_ia32_cvtpi2ps" is undefined __r = __builtin_ia32_cvtpi2ps (__r, __hisi); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(658): error: identifier "__builtin_ia32_movlhps" is undefined __r = __builtin_ia32_movlhps (__r, __r); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(668): error: identifier "__v8qi" is undefined __v8qi __sign; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: identifier "__v8qi" is undefined __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: expected a ")" __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: identifier "__builtin_ia32_pcmpgtb" is undefined __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(676): error: expected a ")" __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(676): error: identifier "__builtin_ia32_punpcklbw" is undefined __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(685): error: identifier "__v8qi" is undefined __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, (__v8qi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(685): error: expected a ")" __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, (__v8qi)0LL); ^ compilation aborted for /sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx (code 4) rm /tmp/icpcCkadMwlibgcc rm /tmp/icpcxPay4xgnudirs rm /tmp/icpcmngmnzgas rm /tmp/icpc1Ts9GAas_.s rm /tmp/icpcCwCX0Bldashv rm /tmp/icpc5aEAmDarg [/bash]
SergeyKostrov
Valued Contributor II
>>...those are linker options...? . Yes, you're right and sorry about this. Last week there was a problem with search paths for libraries and I confused myself and you. Of course, an option '/I' has to be used instead.
KitturGanesh
Thanks for the inout Burlen. Yes, since you're using 11.X version you'll need to use iccvars.sh. In later versions that were released 12.X and now 13.0, you will find the script compilervars.sh that you should execute to set the environment. I'll get back to you after some investigation of the input you attached, thanks. Regards, Kittur
KitturGanesh
Hi Burlen, Well, looking at the log I find the following: The culprit is: --sys_include \ /opt/intel/Compiler/11.1/038/bin/include This means that the headers are not being searched in /opt/intel/Compiler/11.1/038/Compiler/include/intel64 and the driver is using the flat structure to attempt to find the directories in question. If you had installed the compiler correctly, there should be both the /opt/intel/Compiler/11.1/038/Compiler/include and the /opt/intel/Compiler/11.1/038/Compiler/lib/intel64 directories. Sourcing the iccvars.sh ensures the compiler/lib path is set. And, if the compiler/lib and compiler/include paths are not found in the installed directory it assumes a flat include & lib structure and uses those paths. So, please ensure that the /opt/intel/Compiler/11.1/038/Compiler/include/intel64 and /opt/intel/Compiler/11.1/038/Compiler/lib/intel64 are on the system. And set the following path: export CPATH=/opt/intel/Compiler/11.1/038/Compiler/include/intel64:$CPATH to guarantee that the correct compiler include is used. Regards, Kittur
SergeyKostrov
GCC like C/C++ compilers have option '-v' that allows to see all search directories for headers. For example, for a MinGW C++ compiler it looks like: ... ignoring nonexistent directory "../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../mingw32/include" ignoring nonexistent directory "/mingw/include/c++/3.4.2" ignoring nonexistent directory "/mingw/include/c++/3.4.2/mingw32" ignoring nonexistent directory "/mingw/include/c++/3.4.2/backward" ignoring nonexistent directory "/mingw/include" ignoring nonexistent directory "/mingw/include" ignoring nonexistent directory "/mingw/lib/gcc/mingw32/3.4.2/include" ignoring nonexistent directory "/mingw/mingw32/include" ignoring nonexistent directory "/mingw/include" #include "..." search starts here: #include <...> search starts here: ../../AppsSca/include ../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2 ../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/mingw32 ../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include/c++/3.4.2/backward ../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/../../../../include ../MinGW342/Bin/../lib/gcc/mingw32/3.4.2/include End of search list. ... When executed as:. ... @g++.exe -B ../../TestMgwApp -g -D_DEBUG -o Debug\TestMgwAppD.exe TestMgwApp.cpp -v
KitturGanesh
Yes, that's correct. You can use "gcc -print-search-dirs" directly but the MinGW is more readable output than using gcc -print-search-dirs directly.... Regards, Kittur
Burlen_L_
I contacted the sys admin he added the latter to the cpath and the issue is solved. Thanks for all of the great tips and help getting to the bottom of this. I'm very happy that I don't need to be locating these internal compiler directories in my cmake code!
