I'm having an issue with icc on linux, it's using xmmintrin.h from the gcc install. I've tested on 3 systems, each of these has different icc gcc versions :-). On 2 of the systems the build fails, the other it does not. I'm wondering if in newer versions of icc, icc searches its own directories for files before gcc's? or if icc always finds gcc's xmmintin.h first, and on the system where I don't have build errors, it just so happens to be that gcc's xmminrin.h is compatible with the one belonging to icc?
I've been working around by appending -I$INTEL_ROOT/include/{intel64,ia32}. but I don't want to do this if intel automatically does this in it's newer compilers. I want to find a reliable solution for all intel compiler versions.
Burlen
tcprince wrote:I'm using the existing icc installs at hpc centers NERSC,NICS, and TACC. I had assumed that icc was installed correctly on all. however it sounds like you're saying the install is broken if icc ends up using gcc's *mmintin? Are you sure about this?
If you don't interfere with the way icc is installed, it will use only its own implementations of *mmintrin.h, while gcc will use its own.
tcprince wrote:Ufortunately, using immintrin.h instead of xmmintrin.h doesn't make a difference. icc still finds gcc's version of xmmintrin.h.
Possibly a degree of incompatibility comes from the way icc expects you to include the top level immintrin.h and rely on it to include the lower level ones such as xmmintrin.h, while gcc is more oriented toward use of the specific include file which matches your intrinsics.
jljiang wrote:One these systems one would load an environment module to configure the compiler eg. "module load intel". Just to be sure I tried "source /opt/intel/Compiler/11.1/038/bin/iccvars.sh intel64" and it didn't help.
also make sure you run icc or icpc after source compilervars.sh. so the compiler env is setup properly.
Sergey Kostrov wrote:those are linker options...?There are two C++ compiler command line options ( /L and /l ) that control the order of a search for header files in directories. Did you consider it?
Sergey Kostrov wrote:... and intel's intrinsics reference documentation no where mentions not including any of these directly. perhaps it's a good idea to use the higher level include, but if it were necessary I think that it would be more clearly specified in the documentation...>>...Ufortunately, using immintrin.h instead of xmmintrin.h doesn't make a difference...
These two headers are very different and they can not be used as a substitution of one by another:
- xmmintrin.h - is a Principal header file for Streaming SIMD Extensions intrinsics
- immintrin.h - is Intel(R) AVX compiler intrinsics
Kittur Ganesh (Intel) wrote:There's no file named "compilervars.sh" , however there are a number of files named like "${TOOL}vars.sh", for ex. "iccvars.sh". After sourcing this icc still finds gcc's copy of the intrinsics ...If you have sourced the icc script "compilervars.sh intel64", it should have set up the compiler include/lib paths.
Kittur Ganesh (Intel) wrote:-#x output from compilation of a single cxx class follows. Thanks for looking at this! [bash] /opt/intel/Compiler/11.1/038/bin/intel64/mcpcom \ -_g \ -mP3OPT_inline_alloca \ -D__HONOR_STD \ -D__ICC=1110 \ -D__INTEL_COMPILER=1110 \ -D_MT \ "-_Asystem(unix)" \ -D__ELF__ \ "-_Acpu(x86_64)" \ "-_Amachine(x86_64)" \ -D__INTEL_COMPILER_BUILD_DATE=20090511 \ -D__PTRDIFF_TYPE__=long \ "-D__SIZE_TYPE__=unsigned long" \ -D__WCHAR_TYPE__=int \ "-D__WINT_TYPE__=unsigned int" \ "-D__INTMAX_TYPE__=long int" \ "-D__UINTMAX_TYPE__=long unsigned int" \ -D__PIC__ \ -D__pic__ \ -D__LONG_MAX__=9223372036854775807L \ -D__QMSPP_ \ -D__NO_MATH_INLINES \ -D__NO_STRING_INLINES \ -D__NO_INLINE__ \ -D__GNUG__=4 \ -D__GNUC__=4 \ -D__GNUC_MINOR__=3 \ -D__GNUC_PATCHLEVEL__=0 \ -D__NO_INLINE__ \ -D__i686 \ -D__i686__ \ -D__pentiumpro \ -D__pentiumpro__ \ -D__pentium4 \ -D__pentium4__ \ -D__SSE2__ \ -D__tune_pentium4__ \ -D__MMX__ \ -D__SSE__ \ -D__LP64__ \ -D_LP64 \ -D_GNU_SOURCE=1 \ -U__DEPRECATED \ -D__GXX_WEAK__=1 \ -D__GXX_ABI_VERSION=1002 \ "-D__USER_LABEL_PREFIX__= " \ -D__REGISTER_PREFIX__= \ -D__INTEL_RTTI__ \ -D__EXCEPTIONS=1 \ -D__unix__ \ -D__unix \ -D__linux__ \ -D__linux \ -D__gnu_linux__ \ -B \ -Dunix \ -Dlinux \ -D__x86_64 \ -D__x86_64__ \ -_k \ -_8 \ -_l \ -_a \ -_b \ --gnu_version=430 \ -_W5 \ --gcc-extern-inline \ -p \ --bool \ -tused \ -mGLOB_eh_linux \ -x \ --mspp \ --multibyte_chars \ --diag_suppress=279,1170,161,177 \ --honor_f32_conversion=1 \ --honor_f64_conversion=1 \ -DSciberQuestToolKit_EXPORTS \ -DMPICH_IGNORE_CXX_SEEK \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/KWSys \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/KWSys \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/System \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/System \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Transforms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Transforms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/DataModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/DataModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ExecutionModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ExecutionModel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ComputationalGeometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ComputationalGeometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/zlib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/zlib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Legacy \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Legacy \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/HashSource \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/HashSource \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/FlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/FlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/DICOMParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/DICOMParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO/vtkmetaio \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MetaIO \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/jpeg \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/jpeg \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/png \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/png \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/tiff \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/tiff \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Extraction \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Extraction \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Geometry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/expat \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/expat \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XMLParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XMLParser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MaterialLibrary \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MaterialLibrary \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/freetype \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/freetype \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/ftgl \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeType \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeType \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/ParseOGLExt \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/ParseOGLExt \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/EncodeString \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/EncodeString \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/OpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/OpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeTypeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeTypeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Volume \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Volume \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/VolumeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/VolumeOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library/VisItLib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Database \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Pipeline \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Plotter \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/comm \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/expr \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/icons \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/parser \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/plugin \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/proxybase \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/state \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/utility \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/misc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/plugin \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/state \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/utility \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Database \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Ghost \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/MetaData \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/SIL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Math \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/VisWindow/VisWindow \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/IVP \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/AbstractFilters \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Data \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Pipeline \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sinks \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/full \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/lightweight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/boost_1_46_1 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/TestDriver \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/TestDriver \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Infovis/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Infovis/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/MathText \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/MathText \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Charts/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Charts/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/gl2ps \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/gl2ps \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/GL2PS \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/GL2PS \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Export \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Export \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2/vtklibxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/libxml2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Infovis \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Infovis \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Sources \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Hybrid \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Modeling \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Modeling \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/General \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Style \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Style \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Color \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Annotation \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Annotation \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Widgets \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Widgets \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Context2D \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerStream \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerStream \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Programmable \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Programmable \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/PythonSupport \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/PythonSupport \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/Common \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/Common \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/MPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/MPI \ -I/opt/sgi/mpt/mpt-2.04/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Tools \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Tools \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/WrapClientServer \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/WrapClientServer \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf/vtkprotobuf/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/protobuf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/Core \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Domains/Chemistry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Domains/Chemistry \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Cosmo \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Generic \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Generic \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/HyperTree \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/HyperTree \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelFlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelFlowPaths \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Fourier \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Fourier \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/alglib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/alglib \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Statistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Statistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Imaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Imaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelImaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelImaging \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelMPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelMPI \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelStatistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelStatistics \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Texture \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Texture \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Verdict \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5/vtkhdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/src \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/AMR \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/EnSight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/EnSight \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf/vtknetcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/exodusII \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/exodusII \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Exodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Exodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Import \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Import \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/MPIImage \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/MPIImage \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/oggtheora \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/oggtheora \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Movie \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Movie \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/NetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/NetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/PLY \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/PLY \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelExodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelExodus \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/LSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/LSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelLSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelLSDyna \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelNetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelNetCDF \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/VPIC \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases/AvtAlgorithms \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/databases \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Xdmf2 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Morphological \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Morphological \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Image \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Parallel \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT/vtkicet/src/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT/vtkicet/src/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Label \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Label \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Rendering \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Default \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/HybridOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/HybridOpenGL \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/LOD \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/LOD \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/ProcessXML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/ProcessXML \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/SMApplication \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/SMApplication \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/CoProcessor \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/CoProcessor \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/GenericBridge \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/GenericBridge \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Python \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Python \ -I/sw/analysis/python/2.7.1/sles11.1_intel11.1/include/python2.7 \ -I/sw/analysis/osmesa/7.5.1/sles11.1_intel11.1.038/include \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/eigen-3.0.3/eigen-eigen-3.0.3 \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit \ -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Plugins/SciberQuestToolKit \ --sys_include \ /opt/intel/Compiler/11.1/038/ipp/em64t/include \ --sys_include \ /opt/intel/Compiler/11.1/038/mkl/include \ --sys_include \ /opt/intel/Compiler/11.1/038/tbb/include \ --sys_include \ /sw/analysis/python/2.7.1/sles11.1_intel11.1/include \ --sys_include \ /opt/intel/Compiler/11.1/038/include \ --sys_include \ /opt/intel/Compiler/11.1/038/mkl/include \ --sys_include \ /opt/intel/Compiler/11.1/038/ipp/em64t/include \ --sys_include \ /opt/intel/Compiler/11.1/038/tbb/include \ --sys_include \ /opt/sgi/mpt/mpt-2.04/include \ --sys_include \ /usr/include/c++/4.3 \ --sys_include \ /usr/include/c++/4.3/x86_64-suse-linux \ --sys_include \ /usr/include/c++/4.3/backward \ --sys_include \ /opt/intel/Compiler/11.1/038/bin/include \ --sys_include \ /usr/local/include \ --sys_include \ /usr/include \ --sys_include \ /usr/lib64/gcc/x86_64-suse-linux/4.3/include \ --bool \ -mP1OPT_version=11.1-intel64 \ -mGLOB_diag_enable_disable=D:279,D:1170,D:161,D:177 \ -mGLOB_diag_file=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.diag \ -mP1OPT_print_version=FALSE \ -mP3OPT_use_mspp_call_convention \ -mCG_use_gas_got_workaround=F \ -mP2OPT_align_option_used=TRUE \ "-mGLOB_options_string=-I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/KWSys -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/KWSys -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/System -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/System -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Transforms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Transforms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/DataModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/DataModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ExecutionModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ExecutionModel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/ComputationalGeometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/ComputationalGeometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/zlib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/zlib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Legacy -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Legacy -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/HashSource -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/HashSource -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/FlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/FlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/DICOMParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/DICOMParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO/vtkmetaio -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MetaIO -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MetaIO -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/jpeg -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/jpeg -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/png -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/png -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/tiff -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/tiff -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Extraction -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Extraction -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Geometry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/expat -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/expat -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XMLParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XMLParser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/MaterialLibrary -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/MaterialLibrary -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/freetype -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/freetype -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/ftgl -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/ftgl -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeType -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeType -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/ParseOGLExt -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/ParseOGLExt -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Utilities/EncodeString -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Utilities/EncodeString -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/OpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/OpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/FreeTypeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/FreeTypeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Volume -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Volume -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/VolumeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/VolumeOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/Library/VisItLib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Database -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Pipeline -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/Exceptions/Plotter -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/comm -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/expr -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/icons -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/parser -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/plugin -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/proxybase -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/state -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/utility -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/misc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/plugin -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/state -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/common/common/utility -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Database -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Ghost -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Database/Formats -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/MetaData -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/DBAtts/SIL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Math -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/VisWindow/VisWindow -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/IVP -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/AbstractFilters -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Data -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Pipeline -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sinks -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/avt/Pipeline/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/full -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/Library/VisItLib/visit_vtk/lightweight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/boost_1_46_1 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/TestDriver -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/TestDriver -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Common/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Common/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Infovis/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Infovis/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/MathText -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/MathText -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Charts/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Charts/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/gl2ps -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/gl2ps -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/GL2PS -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/GL2PS -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Export -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Export -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2/vtklibxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/libxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/libxml2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Infovis -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Infovis -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Sources -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Hybrid -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Modeling -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Modeling -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/General -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Style -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Style -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Color -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Annotation -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Annotation -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Widgets -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Widgets -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Views/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Views/Context2D -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerStream -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerStream -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Programmable -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Programmable -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/PythonSupport -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/PythonSupport -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/XML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/XML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/Common -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/Common -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Parallel/MPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Parallel/MPI -I/opt/sgi/mpt/mpt-2.04/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Tools -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Tools -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/WrapClientServer -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/WrapClientServer -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf/vtkprotobuf/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/protobuf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/protobuf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/Core -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Domains/Chemistry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Domains/Chemistry -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Cosmo -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Generic -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Generic -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/HyperTree -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/HyperTree -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelFlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelFlowPaths -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Fourier -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Fourier -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/alglib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/alglib -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Statistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Statistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Imaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Imaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelImaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelImaging -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelMPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelMPI -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/ParallelStatistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/ParallelStatistics -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Texture -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Texture -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Filters/Verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Filters/Verdict -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5/vtkhdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/hl/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5/vtkhdf5/src -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/hdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/hdf5 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/AMR -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/EnSight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/EnSight -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf/vtknetcdf/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf/vtknetcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/netcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/netcdf -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/exodusII -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/exodusII -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Exodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Exodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Import -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Import -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/MPIImage -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/MPIImage -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/oggtheora -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/oggtheora -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Movie -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Movie -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/NetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/NetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/PLY -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/PLY -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelExodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelExodus -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/LSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/LSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelLSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelLSDyna -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/ParallelNetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/ParallelNetCDF -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/VPIC -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases/AvtAlgorithms -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/VisItBridge/databases -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/VisItBridge/databases -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2/vtkxdmf2/libsrc -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/ThirdParty/xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/ThirdParty/xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/IO/Xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/IO/Xdmf2 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Imaging/Morphological -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Imaging/Morphological -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Interaction/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Interaction/Image -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Parallel -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT/vtkicet/src/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT/vtkicet/src/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ThirdParty/IceT -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ThirdParty/IceT -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/Label -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/Label -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/VTKExtensions/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/VTKExtensions/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ClientServerCore/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ClientServerCore/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerImplementation/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerImplementation/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Rendering -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/Default -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/HybridOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/HybridOpenGL -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Rendering/LOD -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Rendering/LOD -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Utilities/ProcessXML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Utilities/ProcessXML -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/ParaViewCore/ServerManager/SMApplication -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/ParaViewCore/ServerManager/SMApplication -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/CoProcessing/CoProcessor -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/CoProcessing/CoProcessor -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Testing/GenericBridge -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Testing/GenericBridge -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/VTK/Wrapping/Python -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/VTK/Wrapping/Python -I/sw/analysis/python/2.7.1/sles11.1_intel11.1/include/python2.7 -I/sw/analysis/osmesa/7.5.1/sles11.1_intel11.1.038/include -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/eigen-3.0.3/eigen-eigen-3.0.3 -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit -I/sw/analysis/paraview/next/sles11.1_intel11.1.038/build/Plugins/SciberQuestToolKit -#x -DSciberQuestToolKit_EXPORTS -DMPICH_IGNORE_CXX_SEEK -Wno-deprecated -wd279,1170,161,177 -g -fPIC -o CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o -c" \ -mGLOB_position_independent_code \ -mGLOB_preemption_model=3 \ -mGLOB_cxx_limited_range=FALSE \ -mP3OPT_emit_line_numbers \ -mP2OPT_suppress_unreferenced_locals=FALSE \ -mGLOB_debug_target=GLOB_DEBUG_TARGET_ALL \ -mGLOB_debug_format=GLOB_DEBUG_FORMAT_DWARF20 \ -mGLOB_as_output_backup_file_name=/tmp/icpc1Ts9GAas_.s \ -mIPOPT_activate \ -mGLOB_machine_model=GLOB_MACHINE_MODEL_EFI2 \ -mGLOB_nonstandard_lib \ -mGLOB_maintain_errno \ -mGLOB_noinline_intrinsics \ -mGLOB_use_base_pointer \ -mGLOB_extended_instructions=0x8 \ -mIPOPT_ninl_limit=0 \ -mIPOPT_ninl_user_level=0 \ -mIPOPT_args_in_regs=0 \ -mIPOPT_args_in_regs=0 \ -mPGOPTI_value_profile_use=T \ -mP2OPT_gen_linux_const_pooling=FALSE \ -mGLOB_opt_level=0 \ -mIPOPT_obj_output_file_name=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o \ -mGLOB_linker_version=2.20.0.20100122-0.7.9 \ -mP3OPT_asm_target=P3OPT_ASM_TARGET_GAS \ -mGLOB_obj_output_file=CMakeFiles/SciberQuestToolKit.dir/vtkSQPlaneSourceCellGenerator.cxx.o \ -mGLOB_source_dialect=GLOB_SOURCE_DIALECT_C_PLUS_PLUS \ -mP1OPT_source_file_name=/sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx \ /sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(105): error: identifier "__builtin_ia32_addss" is undefined return (__m128) __builtin_ia32_addss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(111): error: identifier "__builtin_ia32_subss" is undefined return (__m128) __builtin_ia32_subss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(117): error: identifier "__builtin_ia32_mulss" is undefined return (__m128) __builtin_ia32_mulss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(123): error: identifier "__builtin_ia32_divss" is undefined return (__m128) __builtin_ia32_divss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(129): error: identifier "__builtin_ia32_sqrtss" is undefined return (__m128) __builtin_ia32_sqrtss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(135): error: identifier "__builtin_ia32_rcpss" is undefined return (__m128) __builtin_ia32_rcpss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(141): error: identifier "__builtin_ia32_rsqrtss" is undefined return (__m128) __builtin_ia32_rsqrtss ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(147): error: identifier "__builtin_ia32_minss" is undefined return (__m128) __builtin_ia32_minss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(153): error: identifier "__builtin_ia32_maxss" is undefined return (__m128) __builtin_ia32_maxss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(161): error: identifier "__builtin_ia32_addps" is undefined return (__m128) __builtin_ia32_addps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(167): error: identifier "__builtin_ia32_subps" is undefined return (__m128) __builtin_ia32_subps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(173): error: identifier "__builtin_ia32_mulps" is undefined return (__m128) __builtin_ia32_mulps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(179): error: identifier "__builtin_ia32_divps" is undefined return (__m128) __builtin_ia32_divps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(185): error: identifier "__builtin_ia32_sqrtps" is undefined return (__m128) __builtin_ia32_sqrtps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(191): error: identifier "__builtin_ia32_rcpps" is undefined return (__m128) __builtin_ia32_rcpps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(197): error: identifier "__builtin_ia32_rsqrtps" is undefined return (__m128) __builtin_ia32_rsqrtps ((__v4sf)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(203): error: identifier "__builtin_ia32_minps" is undefined return (__m128) __builtin_ia32_minps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(209): error: identifier "__builtin_ia32_maxps" is undefined return (__m128) __builtin_ia32_maxps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(217): error: identifier "__builtin_ia32_andps" is undefined return __builtin_ia32_andps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(223): error: identifier "__builtin_ia32_andnps" is undefined return __builtin_ia32_andnps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(229): error: identifier "__builtin_ia32_orps" is undefined return __builtin_ia32_orps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(235): error: identifier "__builtin_ia32_xorps" is undefined return __builtin_ia32_xorps (__A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(245): error: identifier "__builtin_ia32_cmpeqss" is undefined return (__m128) __builtin_ia32_cmpeqss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(251): error: identifier "__builtin_ia32_cmpltss" is undefined return (__m128) __builtin_ia32_cmpltss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(257): error: identifier "__builtin_ia32_cmpless" is undefined return (__m128) __builtin_ia32_cmpless ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(265): error: identifier "__builtin_ia32_cmpltss" is undefined __builtin_ia32_cmpltss ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(263): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(275): error: identifier "__builtin_ia32_cmpless" is undefined __builtin_ia32_cmpless ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(273): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(283): error: identifier "__builtin_ia32_cmpneqss" is undefined return (__m128) __builtin_ia32_cmpneqss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(289): error: identifier "__builtin_ia32_cmpnltss" is undefined return (__m128) __builtin_ia32_cmpnltss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(295): error: identifier "__builtin_ia32_cmpnless" is undefined return (__m128) __builtin_ia32_cmpnless ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(303): error: identifier "__builtin_ia32_cmpnltss" is undefined __builtin_ia32_cmpnltss ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(301): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(313): error: identifier "__builtin_ia32_cmpnless" is undefined __builtin_ia32_cmpnless ((__v4sf) __B, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(311): error: identifier "__builtin_ia32_movss" is undefined return (__m128) __builtin_ia32_movss ((__v4sf) __A, ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(321): error: identifier "__builtin_ia32_cmpordss" is undefined return (__m128) __builtin_ia32_cmpordss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(327): error: identifier "__builtin_ia32_cmpunordss" is undefined return (__m128) __builtin_ia32_cmpunordss ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(337): error: identifier "__builtin_ia32_cmpeqps" is undefined return (__m128) __builtin_ia32_cmpeqps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(343): error: identifier "__builtin_ia32_cmpltps" is undefined return (__m128) __builtin_ia32_cmpltps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(349): error: identifier "__builtin_ia32_cmpleps" is undefined return (__m128) __builtin_ia32_cmpleps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(355): error: identifier "__builtin_ia32_cmpgtps" is undefined return (__m128) __builtin_ia32_cmpgtps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(361): error: identifier "__builtin_ia32_cmpgeps" is undefined return (__m128) __builtin_ia32_cmpgeps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(367): error: identifier "__builtin_ia32_cmpneqps" is undefined return (__m128) __builtin_ia32_cmpneqps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(373): error: identifier "__builtin_ia32_cmpnltps" is undefined return (__m128) __builtin_ia32_cmpnltps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(379): error: identifier "__builtin_ia32_cmpnleps" is undefined return (__m128) __builtin_ia32_cmpnleps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(385): error: identifier "__builtin_ia32_cmpngtps" is undefined return (__m128) __builtin_ia32_cmpngtps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(391): error: identifier "__builtin_ia32_cmpngeps" is undefined return (__m128) __builtin_ia32_cmpngeps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(397): error: identifier "__builtin_ia32_cmpordps" is undefined return (__m128) __builtin_ia32_cmpordps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(403): error: identifier "__builtin_ia32_cmpunordps" is undefined return (__m128) __builtin_ia32_cmpunordps ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(412): error: identifier "__builtin_ia32_comieq" is undefined return __builtin_ia32_comieq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(418): error: identifier "__builtin_ia32_comilt" is undefined return __builtin_ia32_comilt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(424): error: identifier "__builtin_ia32_comile" is undefined return __builtin_ia32_comile ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(430): error: identifier "__builtin_ia32_comigt" is undefined return __builtin_ia32_comigt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(436): error: identifier "__builtin_ia32_comige" is undefined return __builtin_ia32_comige ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(442): error: identifier "__builtin_ia32_comineq" is undefined return __builtin_ia32_comineq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(448): error: identifier "__builtin_ia32_ucomieq" is undefined return __builtin_ia32_ucomieq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(454): error: identifier "__builtin_ia32_ucomilt" is undefined return __builtin_ia32_ucomilt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(460): error: identifier "__builtin_ia32_ucomile" is undefined return __builtin_ia32_ucomile ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(466): error: identifier "__builtin_ia32_ucomigt" is undefined return __builtin_ia32_ucomigt ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(472): error: identifier "__builtin_ia32_ucomige" is undefined return __builtin_ia32_ucomige ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(478): error: identifier "__builtin_ia32_ucomineq" is undefined return __builtin_ia32_ucomineq ((__v4sf)__A, (__v4sf)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(486): error: identifier "__builtin_ia32_cvtss2si" is undefined return __builtin_ia32_cvtss2si ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(503): error: identifier "__builtin_ia32_cvtss2si64" is undefined return __builtin_ia32_cvtss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(510): error: identifier "__builtin_ia32_cvtss2si64" is undefined return __builtin_ia32_cvtss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(519): error: identifier "__builtin_ia32_cvtps2pi" is undefined return (__m64) __builtin_ia32_cvtps2pi ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(532): error: identifier "__builtin_ia32_cvttss2si" is undefined return __builtin_ia32_cvttss2si ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(548): error: identifier "__builtin_ia32_cvttss2si64" is undefined return __builtin_ia32_cvttss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(555): error: identifier "__builtin_ia32_cvttss2si64" is undefined return __builtin_ia32_cvttss2si64 ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(564): error: identifier "__builtin_ia32_cvttps2pi" is undefined return (__m64) __builtin_ia32_cvttps2pi ((__v4sf) __A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(577): error: identifier "__builtin_ia32_cvtsi2ss" is undefined return (__m128) __builtin_ia32_cvtsi2ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(593): error: identifier "__builtin_ia32_cvtsi642ss" is undefined return (__m128) __builtin_ia32_cvtsi642ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(600): error: identifier "__builtin_ia32_cvtsi642ss" is undefined return (__m128) __builtin_ia32_cvtsi642ss ((__v4sf) __A, __B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: identifier "__v2si" is undefined return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: expected a ")" return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(609): error: identifier "__builtin_ia32_cvtpi2ps" is undefined return (__m128) __builtin_ia32_cvtpi2ps ((__v4sf) __A, (__v2si)__B); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(622): error: identifier "__v4hi" is undefined __v4hi __sign; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(623): error: identifier "__v2si" is undefined __v2si __hisi, __losi; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: identifier "__v4hi" is undefined __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: expected a ")" __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(629): error: identifier "__builtin_ia32_pcmpgtw" is undefined __sign = __builtin_ia32_pcmpgtw ((__v4hi)0LL, (__v4hi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(632): error: identifier "__v2si" is undefined __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(632): error: expected a ";" __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(633): error: expected a ";" __losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(637): error: identifier "__builtin_ia32_cvtpi2ps" is undefined __r = __builtin_ia32_cvtpi2ps (__r, __hisi); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(638): error: identifier "__builtin_ia32_movlhps" is undefined __r = __builtin_ia32_movlhps (__r, __r); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(648): error: identifier "__v2si" is undefined __v2si __hisi, __losi; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(652): error: identifier "__v2si" is undefined __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(652): error: expected a ";" __hisi = (__v2si) __builtin_ia32_punpckhwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(653): error: expected a ";" __losi = (__v2si) __builtin_ia32_punpcklwd ((__v4hi)__A, (__v4hi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(657): error: identifier "__builtin_ia32_cvtpi2ps" is undefined __r = __builtin_ia32_cvtpi2ps (__r, __hisi); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(658): error: identifier "__builtin_ia32_movlhps" is undefined __r = __builtin_ia32_movlhps (__r, __r); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(668): error: identifier "__v8qi" is undefined __v8qi __sign; ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: identifier "__v8qi" is undefined __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: expected a ")" __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(673): error: identifier "__builtin_ia32_pcmpgtb" is undefined __sign = __builtin_ia32_pcmpgtb ((__v8qi)0LL, (__v8qi)__A); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(676): error: expected a ")" __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(676): error: identifier "__builtin_ia32_punpcklbw" is undefined __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, __sign); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(685): error: identifier "__v8qi" is undefined __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, (__v8qi)0LL); ^ /usr/lib64/gcc/x86_64-suse-linux/4.3/include/xmmintrin.h(685): error: expected a ")" __A = (__m64) __builtin_ia32_punpcklbw ((__v8qi)__A, (__v8qi)0LL); ^ compilation aborted for /sw/analysis/paraview/next/sles11.1_intel11.1.038/ParaView/Plugins/SciberQuestToolKit/vtkSQPlaneSourceCellGenerator.cxx (code 4) rm /tmp/icpcCkadMwlibgcc rm /tmp/icpcxPay4xgnudirs rm /tmp/icpcmngmnzgas rm /tmp/icpc1Ts9GAas_.s rm /tmp/icpcCwCX0Bldashv rm /tmp/icpc5aEAmDarg [/bash]
Compile with the option "-#x" and attach the output so I can pass that to our developers for further investigation?
Kittur
Kittur Ganesh (Intel) wrote:I contacted the sys admin he added the latter to the cpath and the issue is solved. Thanks for all of the great tips and help getting to the bottom of this. I'm very happy that I don't need to be locating these internal compiler directories in my cmake code!If you had installed the compiler correctly, there should be both the /opt/intel/Compiler/11.1/038/Compiler/include and the /opt/intel/Compiler/11.1/038/Compiler/lib/intel64 directories.
