Intel® C++ Compiler
7877 Discussions
xutility(809): error : assertion failed: pop_scope
miaoren_x_
I am getting the following error using intel c++ compiller only in debug model
D:\Program Files (x86)\Microsoft Visual Studio 14.0\VC\include\xutility(809): error : assertion failed: pop_scope: unexpected curr_object_lifetime for function or block scope (shared/cfe/edgcpfe/scope_stk.c, line 9045)
1>
1>            _NOEXCEPT_OP(_NOEXCEPT_OP(!_Pred(_Left, _Right))
1>            ^
I am using Visual Studio 2015 Enterprise Update 2  with Intel C++ 16.0 update 3. And I use "using namespace std;" in the header file.
In addition, I use boost 1.16.0 and pybind11 in my project.
The error will not emerge in Release Mode.
When using Visual C++ compiler,  there is no error found.
Is anybody could give me some suggestions.
Xia
Melanie_B_Intel
This looks like a compiler bug.
Can you attach the preprocessed file? (Use the -E switch on the compilation line that fails, redirect standard output to a text file, and attach the text file to your reply.)  Also please show the command line which failed.
Thanks for the report. --Melanie
miaoren_x_
My building command line in VS2015 is
/GS /W0 /Zc:wchar_t /ZI /Od /Fd"x64\Debug\vc140.pdb" /D "_DEBUG" /D "_CONSOLE" /D "_UNICODE" /D "UNICODE" /Zc:forScope /RTC1 /MDd /Fa"x64\Debug\" /EHsc /nologo /Fo"x64\Debug\" /Qprof-dir "x64\Debug\" /Fp"x64\Debug\Energy.pch"  -E
And the output of MSBuild is in file out.txt
miaoren_x_
The out.txt file
Melanie_B_Intel
I can reproduce this problem and I opened DPD200411626 in our internal bug tracking database. Thanks for the report.
Judith_W_Intel
The compiler seems to have a problem because the lambda is a c++14 generic lambda.
If you specify the parameter types to the lambda instead of using "auto" the compiler will work ok, i.e. change the code to match what's inside the #ifdef OK here:
void System::readxyzfile(const std::basic_string &filename) {
#ifdef OK
  typedef shared_ptr<Atom>  param_type;
#endif
  for (auto &mol : mol_lst)
    mol->atom_lst.sort(
#ifdef OK
        [](const param_type& a, const param_type& b) { return a->seq < b->seq; }
#else
        [](const auto &a, const auto &b) { return a->seq < b->seq; });
#endif
miaoren_x_
After change the  c++14 generic lambda, my project can compile with intel  c++ compiller.
Thank you very much for your help.
But I really can' t understand that intel  compiler doesn't support C++14 on windows in the era of GCC6 already set C++14 as default option.
