Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
关于libfdk_aac
han_x_
我按照文档:
2.3.5 Compile and deploy ffmpeg with libfdk_aac
The default ffmpeg library used by MCU server has no libfdk_aac support. If you want to enable libfdk_aac for external stream output, please compile and deploy ffmpeg yourself with following steps:
Note: The libfdk_aac is designated as "non-free", please make sure you have got proper authority before using it.
  1. Go to Release-<Version>/access_agent folder, compile ffmpeg with libfdk_acc with below command:
     compile_ffmpeg_with_libfdkaac.sh
    Note: This compiling script need install all dependencies for ffmpeg with libfdk_aac. If that is not expected on deployment machines, please run it on other proper machine.
  2. Copy all output libraries under ffmpeg_libfdkaac_lib folder to Release-<Version>/access_agent/lib to replace the existing ones.
将编译后的文件夹ffmpeg_libfdkaac_lib中的文件都复制到access_agent/lib,复制后ls命令查看access_agent/lib中文件为:
libapr-1.so.0      libavutil.so.55            libexpat.so.1        libgcc_s.so.1     libopus.so.0.5.0    libuuid.so.1
libaprutil-1.so.0  libboost_system.so.1.54.0  libfdk-aac.so        liblog4cxx.so.10  libstdc++.so.6      libz.so.1
libavcodec.so.57   libboost_thread.so.1.54.0  libfdk-aac.so.1      libopus.so        libswresample.so.2
libavformat.so.57  libbz2.so.1.0              libfdk-aac.so.1.0.0  libopus.so.0      libusrsctp.so.1
我想把本地流推送到rtsp流媒体服务器上,在基本例子script2.js里添加:
conference.addExternalOutput('rtsp://192.168.1.114:554/123.sdp', {streamId: localStream.id()
            }, function () {
              L.Logger.info('Start external streaming success.');
            }, function (err) {
              L.Logger.error('Start external streaming failed:', err);
但还是报错:
ERROR: Start external streaming failed: Can not find audio encoder libfdk_aac, please check if ffmpeg/libfdk_aac installed
还有这个错:
ERROR: Start external streaming failed: Timeout to make rpc to avstream.92cbaffa-21ce-0aee-cf91-d94f330c72f1.0.subscribe
请帮忙看看,多谢!
董宁_郭_
我以前也出过这个,仔细检查了安装日志,发现是ffmpeg缺少一些依赖没编译过
han_x_
非常感谢。没注意编译日志。日志里确实有报错:ERROR: libfdk_aac not found
已经解决了。
