此实现只是demo,可自行优化 import ( "crypto/hmac" "crypto/sha256" "encoding/base64" "fmt" "github.com/gojektech/heimdall" "io" "io/ioutil" "net/http" "strings" "time" "github.com/labstack/echo" "encoding/json" ) //创建房间 func createRoom(url,room string) string{ requestBody := "" result := send(url,"post",requestBody) return result } //url:接口地址 //method: get post ... //requestBody 请求主体 func send(url, method, requestBody string) string { //key key := "" //serviceid serviceid := "" //时间戳 到毫秒 timestamp := utils.ToString(time.Now().UnixNano() / 1e6) //随机数 cnounce := utils.Krand(8, utils.KC_RAND_KIND_NUM) //签名需要的参数 toSign := timestamp + "," + cnounce //签名 signed := calculateSignature(toSign, key) //Header 信息 header := "MAuth realm=http://marte3.dit.upm.es,mauth_signature_method=HMAC_SHA256" header = header + ",mauth_serviceid=" + serviceid header = header + ",mauth_cnonce=" + cnounce header = header + ",mauth_timestamp=" + timestamp header = header + ",mauth_signature=" + signed timeout := 1000 * time.Millisecond httpClient := heimdall.NewHTTPClient(timeout) headers := http.Header{} headers.Set("Content-Type", "application/json") headers.Set("Authorization", header) httpClient.SetRetryCount(2) httpClient.SetRetrier(heimdall.NewRetrier(heimdall.NewConstantBackoff(10, 5))) result := "" switch method { case "get": response, err := httpClient.Get(url, headers) if err != nil { logs.Logger.Error("===============> get send错误处理:" + err.Error()) } defer response.Body.Close() respBody, err := ioutil.ReadAll(response.Body) if err != nil { logs.Logger.Error("===============> get send ReadAll 错误处理:" + err.Error()) } result = string(respBody) break case "post": response, err := httpClient.Post(url, strings.NewReader(requestBody), headers) if err != nil { logs.Logger.Error("===============> post send错误处理:" + err.Error()) } defer response.Body.Close() respBody, err := ioutil.ReadAll(response.Body) if err != nil { logs.Logger.Error("===============> post send ReadAll 错误处理:" + err.Error()) } result = string(respBody) break } return result } //base64编码 func calculateSignature(toSign, key string) string { signed := getHmacCode(toSign, key) return base64.StdEncoding.EncodeToString([]byte(signed)) } //HmacSha265 func getHmacCode(s, key string) string { h := hmac.New(sha256.New, []byte(key)) io.WriteString(h, s) return fmt.Sprintf("%x", h.Sum(nil)) }
- Tags:
- HTML5
- JavaScript*
