12-18 18:54:03.045 8003-8057/? E/art: No implementation found for void org.webrtc.PeerConnectionFactory.nativeInitializeAndroidGlobals(android.content.Context, boolean) (tried Java_org_webrtc_PeerConnectionFactory_nativeInitializeAndroidGlobals and Java_org_webrtc_PeerConnectionFactory_nativeInitializeAndroidGlobals__Landroid_content_Context_2Z)
12-18 18:54:03.045 8003-8057/? W/System.err: java.lang.UnsatisfiedLinkError: No implementation found for void org.webrtc.PeerConnectionFactory.nativeInitializeAndroidGlobals(android.content.Context, boolean) (tried Java_org_webrtc_PeerConnectionFactory_nativeInitializeAndroidGlobals and Java_org_webrtc_PeerConnectionFactory_nativeInitializeAndroidGlobals__Landroid_content_Context_2Z)
12-18 18:54:03.046 8003-8057/? W/System.err: at org.webrtc.PeerConnectionFactory.nativeInitializeAndroidGlobals(Native Method)
12-18 18:54:03.046 8003-8057/? W/System.err: at org.webrtc.PeerConnectionFactory.initializeAndroidGlobals(PeerConnectionFactory.java:67)
12-18 18:54:03.046 8003-8057/? W/System.err: at com.intel.webrtc.base.PCFactory$FactoryHandler.handleMessage(PCFactory.java:269)
12-18 18:54:03.046 8003-8057/? W/System.err: at android.os.Handler.dispatchMessage(Handler.java:102)
12-18 18:54:03.046 8003-8057/? W/System.err: at android.os.Looper.loop(Looper.java:154)
12-18 18:54:03.046 8003-8057/? W/System.err: at android.os.HandlerThread.run(HandlerThread.java:61)
12-18 18:54:03.047 8003-8057/? I/art: System.exit called, status: -1
请问,我将webrtc做成android的一个module,引入到主工程中,.so文件应该怎么引用?
apply plugin: 'com.android.library' android { compileSdkVersion 23 defaultConfig { minSdkVersion 16 targetSdkVersion 22 versionCode 1 versionName "1.0" ndk { abiFilters "armeabi-v7a", "x86" } } buildTypes { release { minifyEnabled false } } packagingOptions{ exclude 'AndroidManifest.xml' } //配置.so文件的引用 sourceSets { main { jniLibs.srcDirs = ['libs'] //将so文件路径(jniLibs)指向"libs"路径,这样就可以把so文件打包到APK的lib文件夹中 } } } dependencies { compile files('libs/woogeenbase.jar') compile files('libs/woogeenconference.jar') compile files('libs/woogeenp2p.jar') compile 'com.facebook.react:react-native:+' }
- Tags:
- HTML5
- JavaScript*
