Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
4.2. version error while screen sharing
Nithin_P_
while doing screen share reusult the following error
Uncaught (in promise) Error: options.audio/video is inconsistent with tracks presented in the MediaStream.
    at t.value (owt.js:9)
    at n.ConferenceClient.publish (owt.js:9)
    at index.js?t=345dsfs8i:236
local stream showing but remote stream not showing at remote end
I have used following code
function publishScreenStream() {
let audioConstraintsForMic = false;
let videoConstraintsForCamera = new Owt.Base.VideoTrackConstraints(Owt.Base.VideoSourceInfo.SCREENCAST);
let constraints = new Owt.Base.StreamConstraints(
audioConstraintsForMic, videoConstraintsForCamera);
//constraints.audio = 'screen-cast';
constraints.extensionId = 'onnmlangiddmngabfpbcegkbmelemcab';//'pdjlcifcbfpbpeaifobhhamknjmdilni';
Owt.Base.MediaStreamFactory.createMediaStream(constraints).then(stream => {
mediaScreenStream = stream;
var streamAttribute = {};
streamAttribute.userName = userName;
streamAttribute.room = room;
streamAttribute.isScreen = true;
localScreenStrm = new Owt.Base.LocalStream(
mediaScreenStream, new Owt.Base.StreamSourceInfo(
'screen-cast', 'screen-cast'), streamAttribute);
let $video = $(`<video autoplay id=${stream.id} style='display:block;width:100%;height:100%;object-fit: contain;'>this browser does not supported video tag</video>`);
$video.get(0).srcObject = stream;
let $testdiv = $('<div id="test'+stream.id+'"></div>');
$testdiv.append($video)
$('.videos-wrap').append($testdiv);
layout();
//$('.local video').get(0).srcObject = stream;
conference.publish(localScreenStrm).then(publication => {
// alert(1)
stream.getVideoTracks()[0].onended = function() {
stopScreenShare();
globalScreenPublication = publication;
screenShareEnable = true;
publication.addEventListener('error', (err) => {
console.log('Publication error: ' + err.error.message);
publication.addEventListener('ended', (err) => {
stopScreenShare();
}, err => {
if (err == 'Error: Could not establish connection. Receiving end does not exist.') {
$('#screenmodal').modal('show');
console.error('Failed to create MediaStream, ' + err);
Nithin_P_
any  update on the above issue ?
