Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
ANDROID SDK CRASHING 4.0
ANIL_K_3
HI,
android sample sdk 4.0 crashing when i click on unpublish after successful call completion
android OS VERSION 7.1.1
tony1
You need to set up your current ID on another client. If you do not set it up, the application will crash.
YanbinZ_Intel
Could you please provide more detail information ?
1. what kind of sample ? Conference or P2P sample ?
2. Could you please provide detail steps and detail crash log information ? And test phone information
Yanbin
ANIL_K_3
HI Yanbim Z.
A) Conference Sample
A) Installed and configured android conference sample apk on all available andorid mobile phone devices  like lenovo etc conatains OS 5,6,7  .
When we hit connect and start publishing video joined into room successfully . Then if we click on "unpublish" button to stop publishing and disconnect the call "APP crashing immediately" with notification on mobile screen " Unfortunately ICS_CONF has stopped". With following error getting in android studio console
com.intel.webrtc.conference.sample E/rtc: #
        # Fatal error in ../../third_party/webrtc/sdk/android/src/jni/pc/mediastream_jni.cc, line 67
        # last system error: 11
        # Check failed: 0 == (reinterpret_cast<MediaStreamInterface*>(j_p))->Release() (0 vs. 2)
        # Unexpected refcount.
        --------- beginning of crash
05-03 11:23:21.291 8364-8399/com.intel.webrtc.conference.sample A/libc: Fatal signal 6 (SIGABRT), code -6 in tid 8399 (pool-1-thread-1)
Sharma__Mukesh
comment this line in unpublish onclick listener
localStream.dispose();
the above line is causing the issue and making the application to crash, this not the complete solution but this will stop crashing your android application
YanbinZ_Intel
We can not reproduce this issue use ios 7.1.1.   And localStream.dispose() is used to Close and dispose all the sources associated with the LocalStreamBe sure that there is no active Publication using this LocalStream before calling this method.
Sharma__Mukesh
Yanbin Z. (Intel) wrote:
We can not reproduce this issue use ios 7.1.1.   And localStream.dispose() is used to Close and dispose all the sources associated with the LocalStream. Be sure that there is no active Publication using this LocalStream before calling this method.
What do you mean by ios 7.1.1
YanbinZ_Intel
Type error, Android os 7.1.1
