你好,我们测试过程中发现,avstream模块rtmp推流模块有流中断的显现,排查了系统日志发现Cluster的日志中显示:
740687:2018-01-11 12:25:44.309 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740692:2018-01-11 12:25:44.310 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740697:2018-01-11 12:25:44.310 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
740698:2018-01-11 12:25:44.310 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740703:2018-01-11 12:25:44.310 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740708:2018-01-11 12:25:44.310 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
740709:2018-01-11 12:25:44.311 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740714:2018-01-11 12:25:44.311 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740719:2018-01-11 12:25:44.311 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
740720:2018-01-11 12:25:44.311 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740725:2018-01-11 12:25:44.311 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740730:2018-01-11 12:25:44.311 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
740753:2018-01-11 12:25:44.337 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740758:2018-01-11 12:25:44.337 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740763:2018-01-11 12:25:44.337 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
740764:2018-01-11 12:25:44.338 - DEBUG: ClusterManager - workerJoin, purpose: session worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740769:2018-01-11 12:25:44.338 - DEBUG: Scheduler - Add worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2 info: { ip: '172.17.44.221',
740774:2018-01-11 12:25:44.338 - WARN: Scheduler - Double adding worker: session.64437be4-0b1d-7085-25bc-5b5548921bc2
显示有很多的double worker,系统清理worker的时候,会把正在使用的worker清理掉,就会引起avstream推流终止,不知道该如何解决这种问题呢?
- Tags:
- HTML5
- JavaScript*
session.64437be4-0b1d-7085-25bc-5b5548921bc2.4101.log:
2018-01-11 11:05:13.235 - INFO: ErizoJS - Connecting to rabbitMQ server... 2018-01-11 11:05:13.389 - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: '172.19.113.88', port: 5672 } 2018-01-11 11:05:13.854 - INFO: ErizoJS - session.64437be4-0b1d-7085-25bc-5b5548921bc2.4101 as rpc server ready 2018-01-11 11:05:13.992 - INFO: ErizoJS - session.64437be4-0b1d-7085-25bc-5b5548921bc2.4101 as monitor ready 2018-01-11 12:25:44.082 - WARN: AmqpClient - Late rpc reply: { data: 'ok', corrID: 639, type: 'callback' } 2018-01-11 12:25:44.086 - WARN: AmqpClient - Late rpc reply: { data: 'ok', corrID: 666, type: 'callback' } 2018-01-11 12:25:44.087 - WARN: AmqpClient - Late rpc reply: { data: 'ok', corrID: 675, type: 'callback' } 2018-01-11 12:25:44.354 - WARN: ErizoJS - Exiting on SIGTERM
avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4510.log:
2018-01-11 11:50:04.352 - INFO: ErizoJS - Connecting to rabbitMQ server... 2018-01-11 11:50:04.374 - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: '172.19.113.88', port: 5672 } 2018-01-11 11:50:04.407 - INFO: ErizoJS - avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4510 as rpc server ready 2018-01-11 11:50:04.414 - INFO: ErizoJS - avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4510 as monitor ready 2018-01-11 12:17:46,459 - INFO: woogeen.RtspOut - Initial audio options channels 2, sample rate: 48000 2018-01-11 12:17:47,216 - INFO: woogeen.RtspOut - Initial video options: 1280x720 2018-01-11 12:25:44.400 - ERROR: Connections - Fault detected on controller (type: node id: session.64437be4-0b1d-7085-25bc-5b5548921bc2.4101 ) of connection: 398035680909833800 and remove it 2018-01-11 12:25:44.401 - ERROR: Connections - Fault detected on controller (type: node id: session.64437be4-0b1d-7085-25bc-5b5548921bc2.4101 ) of connection: 543392283920735200 and remove it 2018-01-11 12:25:44,850 - INFO: woogeen.RtspOut - Closing rtmp://cc1.cssltest.net/origin/C0968BBA2745F5089C33DC5901307461 2018-01-11 12:25:44,850 - WARN: woogeen.RtspOut - No input frames available 2018-01-11 12:25:44.851 - WARN: ErizoJS - Exiting on SIGTERM
avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4509.log:
2018-01-11 11:10:31.269 - INFO: ErizoJS - Connecting to rabbitMQ server... 2018-01-11 11:10:31.290 - INFO: AmqpClient - Connecting to rabbitMQ server OK, hostPort: { host: '172.19.113.88', port: 5672 } 2018-01-11 11:10:31.320 - INFO: ErizoJS - avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4509 as rpc server ready 2018-01-11 11:10:31.326 - INFO: ErizoJS - avstream.9d2db18e-bd3e-4ff9-632b-ff69c843d9ae.4509 as monitor ready 2018-01-11 12:17:36,252 - INFO: woogeen.RtspOut - Initial audio options channels 2, sample rate: 48000 2018-01-11 12:17:37,006 - INFO: woogeen.RtspOut - Initial video options: 1280x720 2018-01-11 12:17:41,424 - INFO: woogeen.RtspOut - Closing rtmp://cc1.cssltest.net/origin/C0968BBA2745F5089C33DC5901307461 2018-01-11 12:17:41,424 - WARN: woogeen.RtspOut - No input frames available 2018-01-11 12:17:41.425 - WARN: ErizoJS - Exiting on SIGTERM
不知道为什么会有两个avstream日志推同一份流这个流实际开始时间是 12:17 ,正常应该是13:13结束,但是12:25就终止了,从日志分析说是session冲突,不清楚为什么这个会冲突。
你使用的MCU是什么版本,部署环境是怎样的,多台机器分布式部署的吗?
我们MCU是3.4的版本,目前是分布式部署,服务器中间使用专线连接的,延时在30ms内
