Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1144 Discussions
Access denied finding property "vendor.debug.bq.dump" on Android with OWT 4.31 or 5.0
Etreta
Hello!
Find this bug on some Android devices, for example:
- Lenovo TB X606X, Android 10
- Meizu M570H, Android 6
- Redmi 9, Android 10q
When try to start stream got this in logs -
I/BufferQueue: [unnamed-17090-3](this:0x75a5382800,id:3,api:0,p:-1,c:-1) BufferQueue core=(17090:xxxx)
E/libc: Access denied finding property "vendor.debug.bq.dump"
I/BufferQueueConsumer: [unnamed-17090-3](this:0x75a5382800,id:3,api:0,p:-1,c:17090) connect(C): consumer=(17090:ru.etreta.a2aw) controlledByApp=true
I/BufferQueueConsumer: [unnamed-17090-3](this:0x75a5382800,id:3,api:0,p:-1,c:17090) setConsumerName: unnamed-17090-3
I/BufferQueueConsumer: [SurfaceTexture-1-17090-3](this:0x75a5382800,id:3,api:0,p:-1,c:17090) setConsumerName: SurfaceTexture-1-17090-3
W/CT: type=1400 audit(0.0:1893): avc: denied { read } for name="u:object_r:debug_bq_dump_prop:s0" dev="tmpfs" ino=6770 scontext=u:r:untrusted_app:s0:c161,c256,c512,c768 tcontext=u:object_r:debug_bq_dump_prop:s0 tclass=file permissive=0
I/org.webrtc.Logging: CameraCapturer: startCapture: 1280x720@24
I/org.webrtc.Logging: Camera1Enumerator: getCameraIndex: Camera 0, Facing back, Orientation 90
I/org.webrtc.Logging: Camera1Session: Open camera 0
I/org.webrtc.Logging: SurfaceViewRenderer: full_renderer: onMeasure(). New size: 1200x1896
I/org.webrtc.Logging: EglRenderer: full_renderersetLayoutAspectRatio: 0.6329114
D/OWT: create offer
D/Camera-JNI: (tid:18375)[MtkJNICameraContext] this:0x75a84afae0 camera->getStrongCount(3)
I/org.webrtc.Logging: Camera1Session: Available fps ranges: [[10.0:10.0], [15.0:15.0], [15.0:20.0], [20.0:20.0], [5.0:30.0], [30.0:30.0]]
E/AndroidRuntime: FATAL EXCEPTION: pool-15-thread-1
Any suggestions how to fix it? Both for debug or release
Etreta
Problem solved.
These devices do not support H264 codec. Switch to VP8/9 makes them work.
