Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Android CS 3.4 leaks VideoSource if LocalCameraStreamParameters.hasVideo() == false
lamian
How to reproduct:
1. prepare a test app which supports both video calls and audio calls.
2. perform video call, everything works normally.
3. preform audio call, everything works normally.
4. perform video call again, camera has no output.
After investigation of CS source code, the problem is inside PCFactory.createMediaStream(LocalCameraStreamParameters parameters)
the original code:
static synchronized MediaStream createMediaStream(LocalCameraStreamParameters parameters) throws WoogeenStreamException {
    initHandlerIfNeeded();
    VideoSource videoSource = mediaSourceFactory.getVideoSource(parameters);
    countDownLatch = new CountDownLatch(1);
    mediaStream = null;
    message = factoryHandler.obtainMessage();
    message.what = 5;
    Object[] objects = new Object[]{videoSource, Boolean.valueOf(parameters.hasVideo()), Boolean.valueOf(parameters.hasAudio())};
    message.obj = objects;
    message.sendToTarget();
    try {
        countDownLatch.await();
    } catch (InterruptedException var4) {
        var4.printStackTrace();
    return mediaStream;
this function will get video source unconditionally, even if parameters.hasVideo() == false
However, when local stream is closing:
static void onLocalStreamClosed(LocalStream stream) {
    if(stream instanceof LocalCameraStream && stream.hasVideo()) {
        mediaSourceFactory.releaseCameraVideoSourceRef();
    if(stream instanceof LocalScreenStream && stream.hasVideo()) {
        mediaSourceFactory.releaseScreenVideoSourceRef();
    if(stream.hasAudio()) {
        mediaSourceFactory.releaseAudioSourceRef();
video source will be released only if stream.hasVideo() == true
so for audio only calls, video source will be leaked and that makes further video call not working.
Proposed solution to fix this issue:
    VideoSource videoSource = parameters.hasVideo() ? mediaSourceFactory.getVideoSource(parameters) : null;
    mediaStream = null;
    message.what = 5;
    try {
    return mediaStream;
the fix is quite straightforward, video source will be created only if parameters.hasVideo() ==  true. tested this solution on several devices and the issue no longer exists.
Thank you!
He_Z_Intel
Thanks lamian! We will fix this in future.
