Android - IOS Publish not working.
I am trying to publish stream in both sides of Android and IOS, i didn't receive either success or fail callback. The same issue there for sending message also not receiving any success or fail callback for cross-platform of ios and android.
- Tags:
- HTML5
- JavaScript*
With JS SDK also we are facing the same issue.
Hi Andy,
Are you talking about the conference mode or P2P mode?
Hi Chunbo,
I am facing issue with conference.
Please make sure you connected to server before publishing or subscribing. You could also take a look at the server side log to see if there is error at server side.
Hi Jianjun,
Thanks for the reply. What do you mean by " connect to server first before publishing or subscribing" ? I just followed the js example which exists in github (https://github.com/open-webrtc-toolkit/owt-client-javascript/blob/master/src/samples/conference/public/scripts/index.js). For know I am running a interval to check whether stream got published or not to republish the stream again.
Thank You,
Jayaram K
