Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
1151 Discussions
Android ics conference sample cannot subscribe remote mix stream
Hr__Z
     We installed intel webrtc v4.1 on Cenos7.4 64bit, the example test ok with chrome,but the android ics conference sample cannot subscribe remote mix stream, Conference client object join method callback is called success, but the conference client object subscribe remote mix stream's onSuccess and onFailure cb method doesn't call.we look into the log,both client and server side didn't give any error.How can we fix it?
Hr__Z
I think it's the ssl problem, after verifying I'll post here.
Hr__Z
lack of cisco open libray installation cause this problem. But android client often crash here: E/AndroidRuntime: FATAL EXCEPTION: pool-1-thread-1 Process: com.intel.www.newmeetingdemo, PID: 3381 java.lang.NullPointerException: Attempt to invoke virtual method 'java.util.List com.intel.webrtc.conference.ConferenceInfo.getRemoteStreams()' on a null object reference at com.intel.www.newmeetingdemo.MainActivity.lambda$subscribeMixedStream$1(MainActivity.java:484) at com.intel.www.newmeetingdemo.-$$Lambda$MainActivity$jk3k7xfqhy2u9qBoQci-VenO5Yw.run(Unknown Source:2) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1162) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:636) at java.lang.Thread.run(Thread.java:764)
Hr__Z
unpublish stream often crash here:
E/AndroidRuntime: FATAL EXCEPTION: pool-8-thread-1
    Process: com.intel.www.newmeetingdemo, PID: 11252
    java.lang.NullPointerException: Attempt to read from field 'long org.webrtc.MediaStream.nativeStream' on a null object reference
        at org.webrtc.PeerConnection.removeStream(PeerConnection.java:782)
        at com.intel.webrtc.base.PeerConnectionChannel.lambda$removeStream$6(PeerConnectionChannel.java:216)
        at com.intel.webrtc.base.-$$Lambda$PeerConnectionChannel$0wv9V1DRpOt_-1mTjOzBmDl-k2c.run(Unknown Source:4)
I/Process: Sending signal. PID: 11252 SIG: 9
He_Z_Intel
Hi Hr,Z
Could you please check whether `conferenceClient.info()` returned NULL or not when join.success was triggered in the situation where below exception happened?
Gopi_Krishna_P
Hi
Hr, Z
Have you found any solution for this ?? i am also facing same issue
刘__扬
Gopi Krishna P wrote:
Hi  :   Wait a few second for get information of conference.
you can use Timer.
E.g
new Timer.schedule(
    new TimerTask() {
        @Override public void run() {
            if (conferenceClient.info() != null) {
                subscribeMixedStream();
                Timer.cancel();
0, 1000);
Hr, Z
引文:
Hr, Z 写道:
Hr__Z
you can use Timer.
E.g
new Timer.schedule(
    new TimerTask() {
                Timer.cancel();
0, 1000);
Hr, Z
引文:
Hr, Z 写道:
change the LocalStream dispose position, after Publication
