I have made a recording of a MCU stream, but the audio quality of the video was very poor. There is lot of background noise and cracking in the sound.
Is there a way to improve this? The Video quality is ok. But with the terrible audio it's not becoming a very usefull video.
I've tried both the options pcmu and opus as the audioCodec settings for the recorded stream.
- Tags:
- HTML5
- JavaScript*
What's the input audio codec when you choose pcmu and opus as the recording audio codec? Or you always leave the input codec as default?
I've tested with the basic example, so no changes are made to the input codec. So the input codec is default.
The sound in the room itself is very clear during when we tested a conversation with 4 users. It is only in the recording were the cracking appears. Listening back from the recording what is told during the conversation is very hard.
Got it. We found default PCMU recording output quality is really not good. But if set output codec as Opus it seems OK. This align with the default meeting output Opus sounds good. We will look at the PCMU recording quality issue, can you please double check the Opus recording quality?
Ok, after examining my javascript code I saw the correct options were not parsed correctly to the recording function so it defaulted always to pcmu, my bad. In Opus quality it is indeed better than pcmu, so it's better usable, still a bit of noise in the background, but that might also be related to the poor quality of the laptop microphone. So I will investigate that a bit more.
We found it's the defect of our product on pcmu style audio generation. Will change the default recording output to opus in coming 3.2.1 patch release and plan to have a thorough solution at next major release 3.3. Thanks for reporting this and your patience.
