I'm trying to broadcast mixed stream to Nginx server (with Nginx rtmp module and HLS is on). But HLS output is broken.
Nginx rtmp stats:
I don't know why it show fps to 0. Here is the liveext app config on the Nginx rtmp:
application liveext {
live on;
record all manual;
record_path /path/to/record;
record_suffix -%d-%m-%y-%H-%M-%S.flv;
sync 10ms;
drop_idle_publisher 60s;
wait_video on;
on_publish http://url/to/publish/api;
on_publish_done http:/url/to/publish_done/api;
on_record_done http://url/to/record_done/api;
hls on;
hls_fragment_slicing aligned;
hls_nested on;
hls_path /path/to/hls;
Any ideas?
- Tags:
- HTML5
- JavaScript*
Here is the Twitch stats. On Twitch, everything is ok but maybe videodatarate:0 RTMP header is the problem for Nginx RTMP module. How we can fix this?
Any news?
Aydin, please refer to https://software.intel.com/en-us/forums/intel-collaboration-suite-for-webrtc/topic/752333, this is our rtmp server configuration, please check whether it can solve your problem
Thank you.
