Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Build iOS sample for iPhone 6s simulator
Chao-Yu_C_
I'm trying to run iOS sample in my Mac Pro simulator
Environment : OS X Yosemite 10.10.5
Xcode 7.1
iPhone 6s simulator
here is my steps:
1.download sample
2.open WoogeenConference
3.check libwoogeen.a and libsioclient.a
Architectures in the fat file: libsioclient.a are: armv7 arm64
4.I use my build version target for x86_64
https://dl.dropboxusercontent.com/u/13961177/libsioclient.a
https://dl.dropboxusercontent.com/u/13961177/libwoogeen.a
5.add them into (Build Phases / Link Binary With Libraries)
6.I get 64 errors like this
https://dl.dropboxusercontent.com/u/13961177/error.txt
"_OBJC_CLASS_$_RTCEAGLVideoView", referenced from:
      objc-class-ref in StreamView.o
  "_OBJC_CLASS_$_RTCICEServer", referenced from:
      objc-class-ref in AppDelegate.o
  "_OBJC_CLASS_$_RTCMediaStream", referenced from:
      objc-class-ref in libwoogeen.a(woogeen_sdk_objc.RTCStream.o)
  "rtc::LogMessage::min_sev_", referenced from:
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_objc.RTCConferenceClient.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_base.stream.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_conf.conferenceclient.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_conf.socketsignalingchannel.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_conf.conferencepeerconnectionchannel.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_base.peerconnectiondependencyfactory.o)
      rtc::LogMessage::Loggable(rtc::LoggingSeverity) in libwoogeen.a(woogeen_sdk_base.peerconnectionchannel.o)
  "rtc::LogMessage::LogMessage(char const*, int, rtc::LoggingSeverity, rtc::LogErrorContext, int, char const*)", referenced from:
      -[RTCConferenceClient initWithConfiguration:] in libwoogeen.a(woogeen_sdk_objc.RTCConferenceClient.o)
      woogeen::LocalCameraStream::~LocalCameraStream() in libwoogeen.a(woogeen_sdk_base.stream.o)
      woogeen::LocalCameraStream::LocalCameraStream(std::__1::shared_ptr<woogeen::LocalCameraStreamParameters>) in libwoogeen.a(woogeen_sdk_base.stream.o)
      woogeen::ConferenceClient::Publish(std::__1::shared_ptr<woogeen::LocalStream>, std::__1::function<void ()>, std::__1::function<void (std::__1::unique_ptr<woogeen::ConferenceException, std::__1::default_delete<woogeen::ConferenceException> >)>) in libwoogeen.a(woogeen_sdk_conf.conferenceclient.o)
      woogeen::ConferenceClient::Subscribe(std::__1::shared_ptr<woogeen::RemoteStream>, std::__1::function<void (std::__1::shared_ptr<woogeen::RemoteStream>)>, std::__1::function<void (std::__1::unique_ptr<woogeen::ConferenceException, std::__1::default_delete<woogeen::ConferenceException> >)>) in libwoogeen.a(woogeen_sdk_conf.conferenceclient.o)
      woogeen::ConferenceClient::Unpublish(std::__1::shared_ptr<woogeen::LocalStream>, std::__1::function<void ()>, std::__1::function<void (std::__1::unique_ptr<woogeen::ConferenceException, std::__1::default_delete<woogeen::ConferenceException> >)>) in libwoogeen.a(woogeen_sdk_conf.conferenceclient.o)
      woogeen::ConferenceClient::Unsubscribe(std::__1::shared_ptr<woogeen::RemoteStream>, std::__1::function<void ()>, std::__1::function<void (std::__1::unique_ptr<woogeen::ConferenceException, std::__1::default_delete<woogeen::ConferenceException> >)>) in libwoogeen.a(woogeen_sdk_conf.conferenceclient.o)
Can anyone give me some hints on how to solve this problem?
Chunbo_H_Intel1
Hi Chaoyu,
Currently, we do not support the simulator. And what's more, we will add the support next release.
Chunbo_H_Intel1
Hi Chaoyu,
