Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Camera not coming on test page
Deepa_G_
I have installed all the components as docuemented in CS_WebRTC_Conference_Server_User_Guide.v2.0.pdf
but the sample application is not working.
Where shud i check what is the issue?
Artem_M_
Your first problem as I told earlier - is node js. Installation instaruction is https://software.intel.com/en-us/forums/topic/538837   At the bottom.
You should install version 0.10.26 vis nvm
The second - in url you should type /?room= 54c3b42b4eb96d917a48ec52   not ?room=1111   because it uses hash of room
Artem_M_
In some other posts there were explanations about propblem with node js install. Did you see them?
Can you attach some logs from start directory. Without them, I think, nobody could help you.
Deepa_G_
Please see below info -- i do not see any error in log except for room name? can i not give any room name? please direct to correct forum post if this was covered earlier.
# node -v
v0.10.33
cat logs/woogeen-controller.stdout
2015-01-25 21:56:43.065  - INFO: RPC - Exchange rpcExchange is open
2015-01-25 21:56:43.070  - INFO: RPC - ClientQueue amq.gen-QGFCvsbLnSIEK9CDvfUcMX is open
2015-01-25 21:56:43.396  - INFO: RPC - Queue erizoController_1 is open
2015-01-25 21:56:43.399  - INFO: ErizoController - server on
 cat logs/woogeen-agent.stdout
Running process
2015-01-25 21:56:44.165  - INFO: RPC - Exchange rpcExchange is open
2015-01-25 21:56:44.184  - INFO: RPC - ClientQueue amq.gen-ArlyaK4h76Sw6y14HzFwn4 is open
2015-01-25 21:56:44.203  - INFO: RPC - Queue ErizoAgent is open
 cat logs/woogeen-app.stdout
2 rooms in this service.
MyRoom Id: 54c3b42b4eb96d917a48ec52
P2PRoom Id: 54c3b42b4eb96d917a48ec53
GET /?room=111 304 11.226 ms - -
GET /woogeen.sdk.js 304 4.434 ms - -
GET /woogeen.sdk.ui.js 304 3.672 ms - -
GET /script2.js 304 2.371 ms - -
GET / 304 1.341 ms - -
GET /woogeen.sdk.js 304 0.806 ms - -
GET /woogeen.sdk.ui.js 304 1.275 ms - -
GET /script2.js 304 1.161 ms - -
eyJ0b2tlbklkIjoiNTRjNTY2Y2Q0YTVlZjI1NGUyZmYzOTQ3IiwiaG9zdCI6IjEwLjAuMC43OjgwODAiLCJzZWN1cmUiOmZhbHNlLCJzaWduYXR1cmUiOiJZVFEwTURKak9EQXpObUpqWXpWa1lUVXhOR0ZqWldGbU56RXhZVGcwTldVM01UY3lZekF6WXc9PSJ9
POST /createToken/ 200 175.158 ms - 196
GET /?room=1111 304 1.037 ms - -
GET /woogeen.sdk.js 304 1.486 ms - -
GET /script2.js 304 0.971 ms - -
GET /woogeen.sdk.ui.js 304 0.976 ms - -
POST /createToken/ - - ms - -
cat logs/woogeen-nuve.stdout
2015-01-25 21:56:37.646  - INFO: RPC - Conected to rabbitMQ server
2015-01-25 21:56:37.652  - INFO: RPC - Exchange rpcExchange is open
2015-01-25 21:56:37.676  - INFO: RPC - Queue nuveQueue is open
2015-01-25 21:56:37.678  - INFO: RPC - ClientQueue amq.gen-wUZ-8eOAjkCz4pUmkakMoC is open
2015-01-25 21:56:43.120  - INFO: CloudHandler - New erizocontroller ( 1 ) in:  10.0.0.7
2015-01-25 21:56:46.591  - INFO: RoomsResource - Representing rooms for service  54c26186f0baab1613a7f6a6
2015-01-25 21:56:57.814  - INFO: TokensResource - Room  111  does not exist
2015-01-25 21:57:33.955  - INFO: TokensResource - Created token for room  54c3b42b4eb96d917a48ec52 and service  54c26186f0baab1613a7f6a6
2015-01-25 21:57:36.872  - INFO: TokensResource - Room  1111  does not exist
2015-01-25 21:58:57.786  - INFO: TokensResource - Room  111  does not exist
2015-01-25 21:59:37.332  - INFO: TokensResource - Room  1111  does not exist
Artem_M_
Deepa_G_
Thank you it is working now -- on LAN with ROOM IDs as below
1. How to use these rooms on WAN
2. How to create more rooms?
Please share if any documentation on this like gettign started
Artem_M_
Nice to hear that!
Previously in version 1.1 there was administrstion panel. May be it will appea in future.
Now - the only way to create room - is vis mongo shell.
mongo has 2 main tables services and rooms.
You should create first in rooms then in services.
in pure mongo shell it will be something like
db.rooms.insert(
                _id: ObjectId("54a9a18e1f0f96f837b7d6d8")
				"name": "Mix Room2"
db.services.update(
        { _id: ObjectId("54a9a18e1f0f96f837b7d6d8") },
        { $addToSet: { rooms: {
             "_id": ObjectId("54b7d1d1b2a1933287391669"),
             "name": "Mix Room2"
In PHP something like:
$serviceId = ""yyyyy;
$roomId = new MongoId();
$name = "xxx";
$insertRoom = array(
            '_id'       =>  $roomId
            ,"name"      =>  $name
$servicesParams = array('_id'=>new MongoID($serviceId));
$insertServices = array(
            '$addToSet'=> array(
                "rooms" => $insertRoom
$rooms->insert($insertRoom);
$services->update($servicesParams,$insertServices);
The only documentation - is that can be downloaded from main page of project
448063
Deepa_G_
Thank you very much for your Prompt response and resolution :)
Appreciate it
I have gone through that user guide it shows only Internal IP(LAN)
I have the server on a public ip to connect over WAN - I see the error log where it is connecting to socket.io on an INTERNAL IP
Navigated to http://<Public IP>:3001/?room=54c3b42b4eb96d917a48ec52
woogeen.sdk.js:9 GET http://10.0.0.7:8080/socket.io/1/?t=1422283560215 net::ERR_CONNECTION_TIMED_OUTwoogeen.sdk.js:9 d.handshakewoogeen.sdk.js:9 d.connectwoogeen.sdk.js:9 dwoogeen.sdk.js:9 c.connectwoogeen.sdk.js:8 c.ConferenceClient.joinscript2.js:138 (anonymous function)script2.js:19 req.onreadystatechange
woogeen.sdk.js:8 ERROR: server connection failed: connection_error
Chunbo_H_Intel1
Hi guys,
Great to see the hot discussion going on here! Thanks for your sharing.
What's more, the new management panel/UI is on its way. You will have it soon. Stay tuned!
Artem_M_
in file woogeen_config.js  you have properties like
// Public erizoController IP for websockets (useful when behind NATs)
// Use '' to automatically get IP from the interface
config.erizoController.publicIP = '136..........'; //default value: ''
// Use '' to use the public IP address instead of a hostname
config.erizoController.hostname = 'xxxxxxx.com'; //default value: ''
config.erizoController.port = 8080; //default value: 8080
// Use true if clients communicate with erizoController over SSL
config.erizoController.ssl = true; //default value: false
I think you should change that values to may it work in WAN too.
Deepa_G_
Hi Artem,
I changed the IP as advised above and I opened port 8080 on the public IP. now when I try to use 2 users I get PEER CONNECTION FAILED and each others video is not visible even on the same computer.
Is there a list of ports I need to open on the Public Interface? Please note I m running the main server and peerserver on the same machines
INFO: stream in conference: 54c3b42b4eb96d917a48ec52
woogeen.sdk.js:8 INFO: subscribing: 54c3b42b4eb96d917a48ec52
woogeen.sdk.js:8 INFO: subscribed: 54c3b42b4eb96d917a48ec52
woogeen.sdk.js:8 INFO: stream published: Ix0sZgifswNU89CIEmOL
woogeen.sdk.js:8 INFO: user left: Object {name: "user", role: "presenter", id: "GUxGEkFTKRqSBluAEmOK", permissions: Object}id: "GUxGEkFTKRqSBluAEmOK"name: "user"permissions: Objectrole: "presenter"__proto__: Object
woogeen.sdk.js:8 INFO: user joined: Object {name: "user", role: "presenter", id: "sedDTpEj1PfnunZPEmOM", permissions: Object}id: "sedDTpEj1PfnunZPEmOM"name: "user"permissions: Objectrole: "presenter"__proto__: Object
woogeen.sdk.js:8 ERROR: 54c3b42b4eb96d917a48ec52 subscribe failed: peer connection failed
woogeen.sdk.js:8 ERROR: publish failed: peer connection failed
Appreciate your help. Thanks
Chunbo_H_Intel1
Hi Deepa,
Main ports on MCU for client connection:
Woogeen ErizoController: 8080 (configurable)
Woogeen Nuve: 3000
Woogeen Streaming: Random Big Port, like 33430, 54578...
Main ports on Peer Server:
8095 for http, 8096 for https
Please make sure those ports are available. And let me know if you still have connection issues.
