Intel® Collaboration Suite for WebRTC
Community support and discussions on the Intel® Collaboration Suite for WebRTC (Intel® CS for WebRTC).
Can't open video capture device.
Somnus_Chen
Dear Solution,
In IE,I code as follow:
window.onbeforeunload=function(){
    if(localStream){
        localStream.close(); //error:cannot find function "getTracks()"
  if(localStream.channel && typeof localStream.channel.close==='function'){
    localStream.channel.close();
If I try to create LocalStream with "{video:{device:'camera',resolution:'vga'},audio:true}", camera will be released after close the IE TAB.But if I try to
 create LocalStream with "{video:false,audio:true}", camera will not be released. It seems that the code in onbeforeunload useless.
How to release my localStream correctly?
Thanks for your help.
Chunbo_H_Intel1
This is how we stop capturing in our sample and no such issue as mentioned by them.
window.onbeforeunload = function(){
    if(localStream){
      p2p.unpublish(localStream,$('#target-uid').val());
    p2p.stop($('#target-uid').val());
Are you using SDK-3.0? Also please make sure stream is unpublished and session stopped before unload the page.
Thanks!
