I have create an empty project (Visual C++) and i have linked all the required libraries.
I get no errors when I build the project but i get a lot of warnings.
After I start the app i get this error message: The code execution cannot proceed because MFPlat.DLL was not found. Reinstalling the program may fix this problem.
I am getting this error only when I am trying to initialize the PeerClient object.
//woogeen::p2p::PeerClient peerClient(peerClientConfiguration, client);
If a remove the line above i will not get this error.
This is a part of the output:
1>------ Build started: Project: Cpp Client, Configuration: Debug Win32 ------
1>LINK : warning LNK4098: defaultlib 'LIBCMT' conflicts with use of other libs; use /NODEFAULTLIB:library
1>woogeen-debug.lib(metrics_default.obj) : warning LNK4099: PDB 'metrics_default_cc.pdb' was not found with 'woogeen-debug.lib(metrics_default.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\metrics_default_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(field_trial_default.obj) : warning LNK4099: PDB 'field_trial_default_cc.pdb' was not found with 'woogeen-debug.lib(field_trial_default.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\field_trial_default_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(differ_vector_sse2.obj) : warning LNK4099: PDB 'desktop_capture_differ_sse2_cc.pdb' was not found with 'woogeen-debug.lib(differ_vector_sse2.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_differ_sse2_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(shared_desktop_frame.obj) : warning LNK4099: PDB 'primitives_cc.pdb' was not found with 'woogeen-debug.lib(shared_desktop_frame.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\primitives_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(desktop_region.obj) : warning LNK4099: PDB 'primitives_cc.pdb' was not found with 'woogeen-debug.lib(desktop_region.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\primitives_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(desktop_geometry.obj) : warning LNK4099: PDB 'primitives_cc.pdb' was not found with 'woogeen-debug.lib(desktop_geometry.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\primitives_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(desktop_frame.obj) : warning LNK4099: PDB 'primitives_cc.pdb' was not found with 'woogeen-debug.lib(desktop_frame.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\primitives_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(window_capturer_win.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(window_capturer_win.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(window_capture_utils.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(window_capture_utils.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(screen_capturer_win_magnifier.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(screen_capturer_win_magnifier.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(screen_capturer_win_gdi.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(screen_capturer_win_gdi.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(screen_capturer_win_directx.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(screen_capturer_win_directx.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(screen_capture_utils.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(screen_capture_utils.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(scoped_thread_desktop.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(scoped_thread_desktop.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(dxgi_texture_staging.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(dxgi_texture_staging.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug\desktop_capture_cc.pdb'; linking object as if no debug info
1>woogeen-debug.lib(dxgi_texture_mapping.obj) : warning LNK4099: PDB 'desktop_capture_cc.pdb' was not found with 'woogeen-debug.lib(dxgi_texture_mapping.obj)' or at 'C:\Users\Shpetim Ahmeti\Documents\teamtime-windows\Debug
Best regards
- Tags:
- HTML5
- JavaScript*
